I'm looking for some frame clips; the type that slip over the frame-rail thickness (u-clip) and have another circular portion to snap-fit some tubing. I have a few on my 71 to locate the differential breather tubing.
I need to run 3/8 fuel-line tubing inside one frame-rail, and I think these clips will work great. I prefer not to drill holes in my frame and these clips seem to be secure. Problem is, can't find them anywhere. Any suggestions are greatly appreciated.
Hi, There are self-sticking anchors for plastic cable ties. You stick the pad to a surface, put the tie through a hole and snug up around a wire. Just an idea; I probably would want at least a couple of more secure tie-downs for the line.
