Poor running 7.3 help!!!
Old Aug 30, 2009 | 02:29 PM
95blowncoupe's Avatar
95blowncoupe
Hello guys and gals,I have an 01 f250 7.3 with 190xxx mi.
The problem is in the mornings,it starts and runs fine but after about an 1/8mi. down the road it starts to lose power and quickly goes to where it will only idle and afew seconds later it is good for another 1/8mi. and so on afew times until finally its good until the next morning.Cooler morning may be a bit worse.Any ideas?Thanks.
Old Aug 30, 2009 | 02:32 PM
zx250's Avatar
zx250
Of the next Riffraff East
Simple things first, Oil and filter condition? Fuel filter condition? Any Check engine light?
Old Aug 30, 2009 | 02:59 PM
95blowncoupe
Could use an oil and filter change,also a fuel filter.I can see where the fuel filter could cause a problem,but the engine oil also?No CEL on though.
Old Aug 30, 2009 | 03:07 PM
zx250's Avatar
zx250
Low or dirty oil is not a friend of our engines. Either can cause all sorts or problems. The main reason it the fact that the injectors us very high pressured oil to make us go. If you're due or past due for a change, or if you're low, I would fix that first before you start chasing the problem. Might not have anything to do with it, but it could be the entire problem.
Old Aug 30, 2009 | 03:44 PM
87 F-150 I6's Avatar
87 F-150 I6
Kinda sounds like your oil is getting too thin, I would change it to Rotella 5w-40 synthetic.
Old Aug 30, 2009 | 03:50 PM
agg_bagg's Avatar
agg_bagg
this happened to me once and it was due to the oil being low, and old. check your oil level and top it off. if it is low then you will see an imediet improvement i would guess. if you can afford it just do an oil change along with a oil and fuel filter.
Old Aug 30, 2009 | 05:27 PM
orng1's Avatar
orng1
Do the oil change and fuel filter at the same time and you'll see what a huge difference it makes. That should take care of your issues. If not come back with more info.
Old Aug 30, 2009 | 05:38 PM
95blowncoupe
Thanks everyone! I will try the above and be back to let you know.
