86 efi running flooded
Old May 20, 2002 | 09:33 PM
shadetree_f150's Avatar
shadetree_f150
Old Jun 13, 2002 | 01:41 AM
Fordmanwithacause's Avatar
Fordmanwithacause
Hello everyone
My truck is running flooded, black smoke out exhaust at idle when it doesnt die.I cleaned the egr and went for a ride opened her up and went back to the house and when i pulled in it wanted to die on my and black smoke was comming out of exhaust.Replaced the egr, fuel pressure regulator, and idle air bypass vavle is working fine. What could be the problem?
Thanks in advance.
Old Jun 18, 2002 | 06:10 AM
tomw's Avatar
tomw
Post 86 efi running flooded
MAP sensor and vacuum lines. Re-check the fuel pressure regulator with/without vacuum. Should drop/pop several PSI 7-8? as vacuum is applied removed. New one could still be flaky. MAP will tell ECM to add more gas as if WOT. Could also be sticking injectors... Lotsa things...
Didja pull the codes? O2 sensor should be going nuts. Catalytic should be getting really hot too...CHerry red?
Too much gas is either commanded or accidental. Commanded would be MAP/ECM/ECT/ACT sensors. Accidental would be bad injector or FPR.
tom
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
