Weekend Progress
Old Aug 29, 2009 | 03:25 PM
create's Avatar
create
Weekend Progress
Hey guys,
It has been a long time since I have posted on here, or even done any work on my truck. I have a baby due in less than month and am determined to get the truck in paint before then. I took the cab down to bare metal yesterday and started on patch panels this morning:
I cut out the gas filler neck/cab corner to replace it with a patch panel. I have a mustang gas tanke mounted in the back in between the frame rails. No more need for this.
Good thing I did, i found a ton of bondo covering a very crappy patch job.
I am going to put the patch panel in, and then rebuild the inside part from under the cab. It will allow me to make the patch line up better.
Anyway, I thought I would share my work. It feels good to get some actual work done. And the cab wasn't as bad as I thought, however there are a few cancer spots on the roof that were simply filled with body filler. I am going to have to cut those and and replace with sheet metal.
Thanks,
Ben
Old Aug 29, 2009 | 03:34 PM
HD74's Avatar
HD74
Nice work and looking good.
Old Aug 29, 2009 | 04:55 PM
19fifty4's Avatar
19fifty4
Nice looking work. Congrats on the new arrival.
Old Aug 29, 2009 | 07:06 PM
create's Avatar
create
Thanks Im excited to finally get it in paint. I have had it for 4 years now.
Old Aug 29, 2009 | 08:51 PM
56panelford's Avatar
56panelford
Glad to hear your making progress, looking good and congradulations to your incoming son or daughter, more helping hands in the future. I haven't even touched my panel all summer and that wasn't the plan. Thanks for the update.
Old Aug 30, 2009 | 02:59 AM
Huntfamily53's Avatar
Huntfamily53
Glad to see you back...always love the pics.
Old Aug 30, 2009 | 03:37 AM
Stephen67's Avatar
Stephen67
Looking good! I'm jealous, still can't work on mine
Old Aug 30, 2009 | 06:19 PM
JimG1098's Avatar
JimG1098
Create,
You cab looks great. How did you remove paint. I am almost ready to start mine. I have a media blaster, but have not put it together yet.
Please let me know what air tools and grits you used
JimG 1098
Old Aug 30, 2009 | 09:52 PM
create's Avatar
create
I used a few different methods actually. I used some stripper on the dash area, which worked okay. For the rest of the cab I used a DA with different grit depending on what I was doing.
Something that worked well though was a poly abrasive wheel attached to an electric angle grinder. I just moved arounda lot and let it do its thing without getting building up any heat, or putting any pressure on it.
ben
Originally Posted by JimG1098
Create,
JimG 1098
Old Aug 31, 2009 | 05:47 AM
spankys56's Avatar
spankys56
Don't get in a hurry on this part take your time. The body work makes the paint job. Winter is comming!!!! Mark
Old Aug 31, 2009 | 07:49 PM
create's Avatar
create
I got the patch cut and tac'd in today. It still needs to move a bit in order for it to fit perfect, but i need an extra set of hands to get that accomplished. I'll have my brother in law stop by tomorrow to help me fit it perfect.
Then I can start the long process of tack welding that thing in.
Old Aug 31, 2009 | 08:05 PM
56panelford
Have you got any pictures of your frame? Looks like you've beefed it up a bit with the tubing.
Old Aug 31, 2009 | 09:07 PM
create's Avatar
create
I boxed it in and built the crossmember. The previous owner had cut out the crossmember under the cab and didnt replace it with anything. Over the years the weight of the cab made the frame bow out a bit.
I straightened it back up and created this crazy looking thing.
Old Sep 1, 2009 | 07:28 AM
56panelford
Looks sturdy,will you run your exhaust between pipes and frame rails?
Old Sep 1, 2009 | 11:48 AM
reg1952's Avatar
reg1952
Whats the red rag for on the end of the running board bracket? I know from experience you need to cover the other 3 to save your shins.LOL
