How to remove front right fender
Hey fellas. I'm new here. Can someone give me step by step instruction on how to remove my front right fender on my 95 <NOBR id=itxt_nobr_2_0 style="FONT-WEIGHT: normal; FONT-SIZE: 100%; COLOR: darkgreen">F150</NOBR> and what tools I'll need. Thanks alot.
I'd recommend a Chiltons or a Haynes manual for starters. 20+ bucks and will give you some reading and background. There is a body work section in the Chiltons.
Also - use the search feature on this list.
I'm sure the process has been done before and posted.
I use my chiltons, as well as advice from this forum and do my thing.
Bear in mind the chiltons and haynes are not the best and have limitations but they are a good place for reference.
Sometimes when the tube is turned off and it's an hour from sleep time I will read a chapter or two just to get a briefing on what's next on my truck-fix-'er-up agenda.
You can read the books in bed until the grease build up on the books starts to stain the sheets. Then the wife will get on your ****.
I have a Vintage VW book like that...John Muirs idiot guide..it's in the garage now.
Have fun
/Ricache
Have fun
/Ricache
