Sponsored by: Real Truck
Fuel problem?
Old Aug 28, 2009 | 07:06 PM
russtinapo's Avatar
russtinapo
Fuel problem?
I have a 99 f-250 super duty with 180k, I have never had a problem with this truck until recent. At first it started when driving in town, it acted as though it was starved for fuel, got it home and went to start it and it idles real rough, again as if it is starved for fuel, but, while idling, I open the water seperator valve, just a tiny bit, it will idle fine, leaks fuel but idles fine.
I have replace the fuel pump on the frame, cam positionig sensor, seals on the incoming, return and feed fuel lines.
I've been out off work for 2 years now and cannot afford to take it to the shop, any help will be greatly appreciated.
Old Aug 28, 2009 | 07:54 PM
orng1's Avatar
orng1
When was the last time you replaced the fuel filter?
Old Aug 28, 2009 | 09:38 PM
russtinapo's Avatar
russtinapo
Fuel problem
Filter is new
Old Aug 28, 2009 | 10:19 PM
orng1's Avatar
orng1
I think you may have an injector or injectors going bad. I hope not, that can get expensive. I did that about a year and ago too, had 3 injectors go bad so just rebuilt them all.
Old Aug 28, 2009 | 10:20 PM
orng1's Avatar
orng1
What is your location so someone local can help you test them.
Old Aug 29, 2009 | 12:19 AM
russtinapo's Avatar
russtinapo
I'm located 20 miles south east of Mesa, AZ
Old Aug 29, 2009 | 12:21 AM
orng1's Avatar
orng1
Does it go away as it's warmed or is it not even driveable?
Old Aug 29, 2009 | 12:30 AM
russtinapo's Avatar
russtinapo
it continues even after it's warmed up, the other day I started it and it idled fine for about a half hour, shut it off, started it again moved it around the yard, shut it off, came out an hour later and it idled like #^@^, you can accelerate to keep it running, but as soon as you let up, it dies, unless you open the drain just a bit.
Old Aug 29, 2009 | 12:39 AM
orng1's Avatar
orng1
Why would opening the drain make it better?
russtinapo's Avatar
russtinapo
after running it a while, and then opening the filter/seperator, the fuel appears to have an excess amount of air bubbles. Normal??
Old Aug 29, 2009 | 01:00 AM
russtinapo's Avatar
russtinapo
I have no idea why it would improve, Are there any other pressure relief valves, or sensors, ?
There's one off the filter/seperator, it's spring loaded, on the fuel return line back to tank
Old Aug 29, 2009 | 01:01 AM
orng1's Avatar
orng1
It shouldn't be to bad, how low on fuel are you. It does suck up air but you may also have a leak somewhere. I haven't taken the fuel tank apart on my truck yet but there is a few mods you can do to helop minimize the air it picks up. You may find your problem by doing those mods.
Hutch and harpoon mods, search for them.
Is there any fuel leaking from the top or inbetween the valley on your truck?
Old Aug 29, 2009 | 01:06 AM
orng1's Avatar
orng1
Thinking about it you may have a lose clamp somewhere inline that's sucking in air.
Old Aug 29, 2009 | 01:16 AM
russtinapo's Avatar
russtinapo
there no fuel on top or anywhere I can see
Old Sep 3, 2009 | 12:32 AM
russtinapo's Avatar
russtinapo
there is a leak in my fuel line between the tank and the filter/seperator, will track it down tomorrow.. Thanks
