holly 4412s
Old Apr 6, 2002 | 07:57 PM
TSunday's Avatar
TSunday
holly 4412s
I just installed a new Holly 0-4412s carburator on a 302 in my 1977 F100. It appears to be flooding itself on start up. I am greatfull for any help offered.
Old Jul 23, 2002 | 09:44 PM
lms39's Avatar
lms39
holly 4412s
we use 4412's on our stock cars, if your carb is new this might not be the problem. you have a center hung float bowl. on the front you will see an adjustment for the float. it looks like a sloted screw and a nut. the screw is the adjustment and the nut is the lock. this operates a needle and seat. back off the lock and remove the needle and seat ( the screw) if the needle is sticking in the seat, fuel will continue to fill the bowl and will cause flooding. the needle should move freely up and down. it's a cheap part to replace if this is the problem. when you reassemble the bowl adjust until the float is parralell with the bottom of the bowl. good luck
Old Jul 23, 2002 | 10:01 PM
Vampiro's Avatar
Vampiro
holly 4412s
like previsiously posted check youe floats
Old Jul 25, 2002 | 11:08 AM
JimmyK1957's Avatar
JimmyK1957
holly 4412s
Old Dec 13, 2007 | 09:37 AM
quintcy's Avatar
quintcy
how do ford 2150 carb and holly 4412 compair. Ive been thinking i should conver my chev 305 to a 2150 since the rotchesters works like crap. never had any problems with ford carbs.
Old Dec 13, 2007 | 10:12 AM
LxMan1's Avatar
LxMan1
Similar, the 4412 is a 500cfm carb with manual choke. Same bolt pattern as the 2150.
Old Dec 13, 2007 | 04:20 PM
quintcy's Avatar
quintcy
has any one out there ever put a motorcraft 2150 carb on a chev. I know the holly will fit with the right adapters {mounting and kick down} but I allready own a few good motorcraft carbs. Any one ever gave this a try.
Eddillard79
May 9, 2014 07:06 PM
webster
Oct 30, 2012 02:28 PM
levilevi2
Sep 19, 2003 03:33 PM
Hidome
Feb 11, 2003 12:29 AM
