Reverse sensor
Old Aug 27, 2009 | 08:26 PM
REDFORDFX4's Avatar
REDFORDFX4
Reverse sensor
Have 2004 supercrew with the reverse sensor. Question is when I first start out and put it in reverse it turns it self off the reverse sensing that is? Any guess as to what this would be?
Thanks
Old Aug 28, 2009 | 12:28 PM
Still Smoking's Avatar
Still Smoking
One of your sensors is bad. I took mine to the dealer and the hooked it up to their computer for free for me only cause I had some problems with my truck. They say the passanger side outer one goes out 9 times out of 10. Mine was the passanger side inner one though. Take them out and spray the connectors with wd40 and try it again. May just need cleaning. Also check the faces of them and see if any are damaged.
Old Sep 1, 2009 | 05:59 PM
REDFORDFX4's Avatar
REDFORDFX4
Well took a look at them and found that the plug on the drivers side is broke probably from a rock. Next quetion how hard is it to replace the plug?
Pyancey
Jan 16, 2013 09:08 PM
dawson735
Oregon Chapter
Oct 28, 2012 09:50 AM
highboy75
Oct 11, 2011 10:56 AM
Mattias
Jul 26, 2002 12:24 PM
knuckles
Jul 11, 2001 11:13 PM
