Checking for vacuum leaks refresher
Old Jul 28, 2002 | 05:42 PM
Vampiro's Avatar
Vampiro
Old Aug 1, 2002 | 08:26 AM
mxer201's Avatar
mxer201
When trying to pin point a vacuum or air intake leak I believe I remember hearing or reading about spraying something that will cause the idle to increase when the substance is sucked in by the problem area. Any suggestions or ideas? Thanks!!
Old Aug 1, 2002 | 08:47 AM
vettehauler's Avatar
vettehauler
I use WD-40 to test for vacuum leaks. I start slowly, and doing as you say, I spray it on one hose/fitting at a time. If there is a vacuum leak then when the WD-40 hits it, it does cause a slight increase in idle. If I find a leak, I fix it, and continue to check for leaks. (often times I find there is more than one, so I dont stop until I have finished the entire job)
The other good thing is that as I wipe up the excess WD-40, it gives me a chance to clean the areas I sprayed.
good luck
Drew
Old Aug 1, 2002 | 08:52 AM
AOGDEN's Avatar
AOGDEN
I've always used carb. cleaner to check for vacuum leaks. I don't suppose it makes much difference.
Old Aug 1, 2002 | 10:05 AM
Vampiro's Avatar
Vampiro
either or will work fine. just spray the hoses end to end with ti. if the stuff bubbles or gets sucked in, theres the leak
Old Aug 2, 2002 | 05:09 AM
DailyDriver's Avatar
DailyDriver
I've used starting fluid to try and find vaccum leaks. It evaporates quickly so there's no mess to wipe up.
Old Aug 2, 2002 | 09:27 AM
lanero's Avatar
lanero
I've heard of using a spray bottle of water to look for leaks also. Instead of the engine revving up, it will bog down.
I think I would feel safer spraying water instead of something
flammable. IMHO
Roger Lane
Old Aug 2, 2002 | 09:36 AM
vettehauler
I would be sceptical of water in checking for a vacuum leak. I think that trace amounts of moisture would be undetectable, and as a result you would probably miss a small leak.
Thats just my $0.02.
Drew
Old Aug 2, 2002 | 03:06 PM
Vampiro's Avatar
Vampiro
i agree with vettehauler. carb cleaner or WD 40. they evaporate qiuckly and can detect even small leaks
Old Aug 2, 2002 | 03:52 PM
beartracks's Avatar
beartracks
A small hose hooked to a propane source works really well. To get the engine to speed up you have to feed it something combustible but keep it away from the air cleaner or you'll get a false reading.
