Injectors are not injecting!! Why???
There is pressure in the fuel rails, truck turns over fine, firing order is correct, timing is correct.
when attemping to start...acts as if there is no fire. i checked the plugs after trying to start...
they were dry. it seems to me that the injectors are not injecting!!
What could cause this??
oh..the injector wiring harness is plugged in and grounded. i don't know what else to look for.
Thanks for all the info.
Jared PSU tailgater
