Sponsored by: Real Truck
Water / Methanol Injection Kit?
Old Aug 27, 2009 | 02:22 PM
mountaineer27's Avatar
mountaineer27
just wondering if anyone is running one of these kits? what kinda improvments does it make on a turbo-diesel? looking at maybe getting one but not sure if its worth the money
Old Aug 27, 2009 | 03:56 PM
jdadamsjr's Avatar
jdadamsjr
Some have reported lower intake charge temps, which creates 'denser' air to burn, and
with that more power and a bit more of a clean burn....
I researched it a lot and some I knew had it... but while under warranty did not want to 'rock the boat' so stayed away....
but in 9k miles I will be researching again
very important to not run too high mix that it causes problems - forget the number but 10% ? mix with water ?
Old Aug 27, 2009 | 04:33 PM
jrandol's Avatar
jrandol
I had one on a Highly Modified 24valve Cummins. It was this brand http://www.snowperformance.net/index.php
Works as reported. IIRC my EGT's dropped about a 100-130degrees pre-turbo and with the Methanol mix it did increase HP. How much, I honestly don't remember, but it did crank out more on the dyno
The hardest thing I remember when I installed mine was to get the timing right as to when the injection kicked in. Do it to low and your truck will feel like 2 cylinders just dropped out, do it too high and it kinda loses the effect.
Schmitty
15
Jan 11, 2015 06:39 AM
kyle6241
Jan 3, 2014 07:15 AM
ford 400 outlaw
Mar 10, 2013 11:49 AM
michaelsmith9391
17
Feb 10, 2011 07:31 PM
1982_f150
Jul 6, 2007 07:31 PM
