Decoding Codes
Old Aug 27, 2009 | 11:41 AM
Gage2502's Avatar
Gage2502
Cool Decoding Codes
Hey guys my 2000 Expedition 5.4L 4x4 just threw a few codes and is running rough.
Can anyone help me decode them.
Codes:
P0306
P0000
P1000
Thanks ~Gage~
Old Aug 27, 2009 | 12:24 PM
RedHorse1's Avatar
RedHorse1
P0306 Cylinder 6 Misfire Detected
P0000 ???
P1000 OBD-II Monitor Testing Incomplete
Old Aug 27, 2009 | 02:09 PM
Gage2502's Avatar
Gage2502
Ok thanks, for the Cylinder 6 Misfire how do I fix that, new COP? Plug?
Thanks for the info
Why did this come up P1000 OBD-II Monitor Testing Incomplete?
Thanks ~Gage~
Old Aug 27, 2009 | 03:10 PM
RedHorse1's Avatar
RedHorse1
I'd guess either the COP or plug on #6 - maybe both. Could swap one of the other cylinder's COP with #6 and see if the problem moves. I think OE type COPs are ~$50. ea.
I haven't a clue about the P1000, sorry. There's loads of super experienced people posting here so someone should be able to help out there.
Old Aug 27, 2009 | 04:25 PM
Gage2502's Avatar
Gage2502
Thanks for the help, I changed the COP and now its runs like before. Im going to take it to work tomorrow and see if I still get any codes.
I also didnt find anything out about the P1000 code. If I find anything I will post.
On another note LOOK I have more than a 1000 posts now =)
Thanks again ~Gage~
Old Aug 27, 2009 | 06:29 PM
cbradford's Avatar
cbradford
This may explain your P1000 code:
https://www.ford-trucks.com/forums/5...ncomplete.html
Old Aug 27, 2009 | 08:11 PM
cbradford's Avatar
cbradford
Also found this:
Ford Motor Company Driving Cycle
Description of OBDII Drive Cycle
The following procedure is designed to execute and complete the OBDII monitors and to clear the Ford P1000, I/M readiness code. To complete a specific monitor for repair verification, follow steps 1 through 4, then continue with the step described by the appropriate monitor found under the "OBDII Monitor Exercised" column. When the ambient air temperature is outside 4.4 to 37.8°C (40 to 100° F), or the altitude is above 2438 meters (8000 feet), the EVAP monitor will not run. If the P1000 code must be cleared in these conditions, the PCM must detect them once (twice on some applications) before the EVAP monitor can be "bypassed" and the P1000 cleared. The Evap "bypassing" procedure is described in the following drive cycle.
The OBDII Drive Cycle will be performed using a scan tool. Consult the instruction manual for each described function. NOTE: A detailed description of a Powertrain Control Module (PCM) Reset is found in this section, refer to the table of contents.
Drive Cycle Recommendations:
* Most OBDII monitors will complete more readily using a "steady foot" driving style during cruise or acceleration modes. Operating the throttle in a "smooth" fashion will minimize the time required for monitor completion.
* Fuel tank level should be between 1/2 and 3/4 fill with 3/4 fill being the most desirable.
* The Evaporative Monitor can only operate during the first 30 minutes of engine operation. When executing the procedure for this monitor, stay in part throttle mode and drive in a smooth fashion to minimize "fuel slosh".
WARNING
STRICT OBSERVANCE OF POSTED SPEED LIMITS AND ATTENTION TO DRIVING CONDITIONS ARE MANDATORY WHEN PROCEEDING THROUGH THE FOLLOWING DRIVE CYCLES.
For best results, follow each of the following steps as accurately as possible:
OBDII Monitor
Exercised
Drive Cycle Procedure
Purpose of
Drive Cycle
Preparation 1. Install scan tool. Turn key on with the engine off. Cycle key off, then on. Select appropriate Vehicle & Engine qualifier. Clear all DTC's/ Perform a PCM Reset. Bypasses engine soak timer. Resets OBDII Monitor status.
2. Begin to monitor the following PIDs: ECT, EVAPDC, FLI (if available) and TP MODE.
Start vehicle WITHOUT returning to Key Off.
3. Idle vehicle for 15 seconds. Drive at 64 Km/h (40 MPH) until ECT is at least 76.7°C (170° F).
Prep for Monitor Entry 4. Is IAT within 4.4 to 37.8°C (40 to 100° F)? If Not, complete the following steps but, note that step 14 will be required to "bypass " the Evap monitor and clear the P1000. Engine warm-up and provide IAT input to the PCM.
HEGO 5. Cruise at 64 Km/h (40 MPH) for up to 4 minutes. Executes the HEGO monitor.
EVAP 6. Cruise at 72 to 104 Km/h (45 to 65 MPH) for 10 minutes (avoid sharp turns and hills) Note, to initiate the monitor: TP MODE should =PT, EVAPDC must be >75%, and FLI must be between 15 and 85% Executes the EVAP Monitor (If IAT is within 4.4 to 37.8° (40 to 100°F))
Catalyst 7. Drive in stop and go traffic conditions. Include five different constant cruise speeds, ranging from 40 to 72 Km/h (25 to 45 MPH) over a 10 minute period. Executes the Catalyst Monitor.
EGR 8. From a stop, accelerate to 72 Km/h (45 MPH) at 1/2 to 3/4 throttle. Repeat 3 times. Executes the EGR Monitor.
SEC AIR/CCM (Engine) 9. Bring the vehicle to a stop. Idle with transmission in drive (neutral for M/T) for 2 minutes. Executes the ISC portion of the CCM.
CCM (Trans) 10. For M/T, accelerate from 0 to 80 Km/h (o to 50 MPH), continue to step 11. For A/T, from a stop and in overdrive, moderately accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop vehicle and repeat without overdrive to 64 Km/h (40 MPH) cruising for at least 30 seconds. While at 64 Km/h (40 MPH) , activate overdrive and accelerate to 80 Km/h (50 MPH) and cruise for at least 15 seconds. Stop for at least 20 seconds and repeat step 10 five times. Executes the transmission portion of the CCM.
Misfire & Fuel Monitors 11. From a stop, accelerate to 104 Km/h (65 MPH). Decelerate at closed throttle until 64 Km/h (40 MPH) (no brakes). Repeat this 3 times. Allows learning for the misfire monitor.
Readiness Check 12. Access the ON-Board System Readiness (OBDII monitor status) function on the scan tool. Determine whether all non-continuous monitors have completed. If not, go to step 13. Determines if any monitor has not completed.
Pending Code Check and Evap Monitor "Bypass" Check 13. With the scan tool, check for pending codes. Conduct normal repair procedures for any pending code concern. Otherwise, rerun any incomplete monitor.
Note: if the EVAP monitor is not complete AND IAT was out of the 4.4 to 37.8° C (40 to 100° F) temperature range in step #4, or the altitude is over 2438 m. (8000 ft.), the Evap "bypass" procedure must be followed.
Proceed to step 14. Determines if a pending code is preventing the clearing of P1000.
Evap Monitor "Bypass" 14. Park vehicle for a minimum of 8 hours. Repeat steps 2 through 12. DO NOT REPEAT STEP 1. Allow the "bypass" counter to increment to two.
Old Aug 29, 2009 | 11:04 AM
Gage2502's Avatar
Gage2502
Thanks for the info, so far so good.
~Gage~
Samsn4
21
Aug 27, 2014 05:47 PM
68f250guy
Oct 15, 2009 12:08 PM
spitfireal
Apr 23, 2006 07:10 AM
