shaking and shimmy and bounce all over the road
bought an 89 f-150 4X4 yesterday, with a 300 inline six. test drove it everything was fine (for a 20 yr old truck). drove it to work and home. The closer i got to home, everytime i'd put on the brakes, the whole truck would start to shimmy and shake, eventually it became more of a bounce. I thought it could be the rotors, possibly a caliper going out, but nothing i've ever experienced seemed to really explain how or why this would happen. Also, i think it's noteworthy to mention that the truck would still "bounce" (and it was no small bounce, very exaggerated) even after i let off the brake and started to speed up again. Then it would stop. Any help would be greatly appreciated. If i need to provide any more information let me know. Thanks in advance guys.
on
The brakes are the cause if the vibration only happen when they're applied. Steering and suspension parts can be inspected for play and slop by jacking up the fromnt end, everything should be tight, do up/down movement in the ball joints or bearings, wheel should spin without noise, and should be very little free play in the steering linkage.
on
That would be warped rotors, this can be seen by spinning the rotor with the wheel removed, a straight rotor will be the same distance from both pads all the way around while a warped rotor will touch at some points and not at others. Sometimes there's enough metal to machine this out but not if they're warn heavily already, a shop that does brake work will be able to tell you.
I have the same problem...gets pretty violent when it happens. I know this doesn't sound right, but I feel it from the rear end. I was told by my wise(old) mechanic neighbor that it probably has something to do with a brake line sticking. Which might make sense since I rarely use the e-brake and this only happens after I would use it...so pretty much I don't use the emergency brake and it doesn't happen... but if you have an auto, then you probably don't use the e-brake, in which cause you can disregard all my gibberish.
Hmmm....mine got pretty violent too. I gave it a once over last night, though i didn't have much time. I found that one of the pins that holds the caliper on, on the drivers side was just almost completely out, I'm sure that was having some effect. I also noticed that the u joint on the rear of the driveshaft (going into the rear end) needed replacing, wiggled too much (almost 1/8 of an inch). Think either of these or maybe a combination of both was causing my problems? Again, any help greatly appreciated.
WhiteBeast-05-powers
05-27-2014 12:26 PM
BigNug45
08-06-2013 10:58 PM
frisbie6
01-25-2010 08:39 AM
jpbrad0215
1997-2006 Expedition & Navigator
08-29-2006 08:22 PM
