Holley Carb
Old Jul 4, 2002 | 04:31 PM
dpoelstra's Avatar
dpoelstra
Holley Carb
I have an 86 F350 460/C6 crew cab dually. It has a Holley carb with a list number of 50262-2 on it. Does anyone know what this is? Is it aftermarket? A good Carb? CFM? It needs rebuilding, so I am wondering if it is worth it or changing it to say, and Edlebrock.
Thanks
Old Aug 10, 2002 | 02:49 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Holley Carb
Dan, I don't have any information for you, but I have a Holley 2v that I want to ID and don't know where to look for the numbers.
Where did you find the numbers on your carb?
Old Aug 12, 2002 | 04:59 PM
cjcathey2002's Avatar
cjcathey2002
Holley Carb
are you possitive its a holley>? this is direct from the holey web site:
The list number for most performance and factory 2 and 4 barrel carburetors will be found stamped into the upper right hand corner of the airhorn or sometimes called the choke tower. On the 4150 HP models that do not have a choke tower the list number will be stamped into the mainbody behind the throttle linkage. This number is used to identify the carburetor and also used when needing service parts or renew kits.
once you have the number click this link and it will take you to a listing of carbs which will tell you a lot about then carb and any part you may need for it.
http://www.holley.com/HiOctn/ProdLine/CarbList.pdf
1977 F250 460
C6 Hedman Headers
Dual 40 series
edelbrock performer
holley 4160
msd 6a and blaster coil
Old Aug 12, 2002 | 05:03 PM
cjcathey2002
Holley Carb
i just checked and i cant find a listing for 50262-2. sorry about that.
1977 F250 460
C6 Hedman Headers
Dual 40 series
edelbrock performer
holley 4150
Old Aug 14, 2002 | 03:29 PM
horsepuller
FTE Emeritus
Holley Carb
Thanks for the info on where to find the model number.
Old Aug 15, 2002 | 03:05 PM
laptopgeek's Avatar
laptopgeek
Holley Carb
tyrantsparky
Dec 7, 2014 10:25 AM
mgargiullo
Jan 29, 2014 10:57 AM
Raptor119
Apr 8, 2012 12:25 PM
klatt_89
May 10, 2007 08:32 AM
btxbrnco
Mar 22, 2004 11:13 AM
