93 F250 clutch problems
Old Aug 26, 2009 | 04:21 AM
deputy1515's Avatar
deputy1515
Hey guys- looking for some help with some clutch problems.
93 F250 460
In the last two years it has gone through 2 slave cylinders. It is blowing slave cylinder seals. Shifts fine, feels normal, then suddenly pedal goes to the floor and fluid leaking all over. Slave cylinder seals blown out. Local garage has replace it twice in the last two years and it just went out again. Why is it doing this? Any ideas?
I appreciate any help you all can give.
Old Aug 26, 2009 | 01:29 PM
andym's Avatar
andym
It is probably because the shop is using a cheap replacement part. Get a motorcraft from the dealer and it will last a lot longer.
Old Aug 26, 2009 | 02:22 PM
deputy1515's Avatar
deputy1515
All Motorcraft parts and the local garage was the local Ford dealer.
Old Aug 26, 2009 | 02:27 PM
andym's Avatar
andym
Sorry I never heard of this happening before. This is an external slave cylinder, right?
Old Aug 26, 2009 | 05:05 PM
85e150's Avatar
85e150
Is it blowing out due to overtravel? Too much clearance in the mechanism might allow the piston to travel too far, causing seal problems.
Is the master overdoing it? Excessive pressure after the slave has reached the end of it's travel?
My official WAGs.
Old Aug 28, 2009 | 10:04 AM
davelance01's Avatar
davelance01
replace your clutch master cylinder. Bleed and rock on man. I learned the hard way too, when you replace one replace the other at the same time even if there is nothing wrong with it. That advice came from a dealer mechanic with 18 years at ford and it worked for me. Ford hydraulic clutch systems has been a problem since the day the engineers conceived the concept. They do sell a cable conversion kit if you want to ditch the hydraulic system.
Dave
jkschneider
21
Jan 25, 2013 12:42 AM
duckshepherd
1983 - 2012 Ranger & B-Series
Mar 19, 2011 02:01 AM
Pkupman82
Dec 9, 2010 10:28 PM
bigtread
May 20, 2007 06:47 PM
Dwid
13
Aug 21, 2006 11:51 AM
