6.9 or 7.3
Old Aug 25, 2009 | 10:16 PM
black92's Avatar
black92
6.9 or 7.3
I'm considering an idi diesel for my bronco. I've talked to kenpobuck and after reading some the posts on here I'm wondering should the 7.3 be avoided? Also what kind of power and torque are these motors capable of reliably. Are there differences such as some heads better than others or are they pretty much all the same?
Thanks
Old Aug 25, 2009 | 11:19 PM
joe f350's Avatar
joe f350
i would go 6.9 the best year of 6.9 is 87 170 hp 300 na foot pounds of tourge i think there very under rated with a turbo u can get 270 and 500 that put u above a 97 power stroke
Old Aug 26, 2009 | 06:59 AM
IHdieselfan's Avatar
IHdieselfan
I wouldn't turn around for the difference in the two of them. your gonna need coolant conditioner in a 6.9 any way.
Old Aug 26, 2009 | 07:52 AM
rupejosh's Avatar
rupejosh
they are both good motors the 7.3 is a little more prone to cavitation but as long as you do proper maintnence you wont have an issue.they are both really good motors
Old Aug 26, 2009 | 09:55 AM
84 f250 6.9's Avatar
84 f250 6.9
correction joe 6.9 made peak power in 83-86 years at 315 ft lbs and 170 hp but with 4:10 gears it feels like a whole lot more!
Old Aug 26, 2009 | 12:30 PM
joe f350's Avatar
joe f350
yea but un 87 in had the 7.3 head put on it
Old Aug 26, 2009 | 09:08 PM
IHdieselfan
there's no such thing as a 6.9 with 7.3 heads and further more the only difference in the heads is the head bolt size is bigger on the 7.3 to help with clamping force due to the little higher compression ratio.
Old Aug 26, 2009 | 09:31 PM
joe f350's Avatar
joe f350
i ment to as it had the same rockers as the 7.3
Old Aug 26, 2009 | 10:25 PM
dyoung14's Avatar
dyoung14
you need to ride in mine with the 3.55 gears
Old Aug 26, 2009 | 11:05 PM
joe f350's Avatar
joe f350
oh yea take a ride in the my panzer u will never for get it it blose dyoung14 out of tthw watter
Old Aug 27, 2009 | 04:35 PM
ford390gashog's Avatar
ford390gashog
Not true! The glow plug angle was chnged and the injectors were retracted to lower compression. The 7.3 has lower compression than a 6.9.
Old Aug 27, 2009 | 07:10 PM
Dave Sponaugle's Avatar
Dave Sponaugle
Actually the pre combustion chambers are larger in the 7.3 heads which is why the compression dropped from 22.5 to 1 to 21.5 to 1.
6.9 = 18.34 cm3
7.3 = 20.42 cm3
Yes the injectors were retracted, but that was for emissions.
Also the glow plug angle changed to move the glow plug tip in the precup chamber.
Head design changes -
6.9 features "centered" glow plugs, while 7.3 are "off-center"
Injection nozzles have been retracted on the 7.3 .060" to facilitate Federal and state emission certs.
Old Aug 28, 2009 | 09:34 AM
black92's Avatar
black92
So are there any issues I should look for that should be considered deal breakers when buy one of these motors? I might try to find 7.3 turbo. Did they put the E40D behind any of those? The only things I know about these motors is what I've read on this forum lately. Thanks for the input.
Old Aug 28, 2009 | 01:11 PM
joe f350's Avatar
joe f350
u would have to but a compter cause the e4od is fully elctronly controled
Old Aug 28, 2009 | 06:03 PM
Dave Sponaugle
My preference would be an 87 6.9.
Best year for the 6.9, thicker cylinder walls that allow a bore and rebuild, less issues with cavitation.
However when you tear it down, if you are planning on a turbo, use head studs when you put it back together.
A diesel E4OD will bolt to either motor.
