Starter Replacement...Now no power
Old Sep 8, 2009 | 10:24 PM
erbenson's Avatar
erbenson
Homer - thanks. The core was already turned in, so stealing the solenoid off isn't an option.
I'll start calling around tomorrow to see if I can find a solenoid.
-Eric
Old Dec 28, 2009 | 08:17 PM
Reagan K's Avatar
Reagan K
start
got wires off, including ground, with stud, got the top bolt out, and pulled on starter, nothing. is there a third bolt or could it need a little tap or 2. thanks
Old Dec 28, 2009 | 09:05 PM
OkLaHoMaF150's Avatar
OkLaHoMaF150
3 bolts...it's up there hiding. It's a PITA to get to. I hope you have skinny hands. I had to use a deep socket and a 6'' ext. with a rachet. I could only get 1/8 of a turn on it. It took a while.
Old Dec 28, 2009 | 09:13 PM
Piratetech's Avatar
Piratetech
Reman Alternators
My advice is to find a local auto electric shop. Normally 1/3 of the reman price, you have your original, and its better workmanship to boot. Plus keep a workin man employed. I have had 3 bad remans, but never 1 bad rebuild!
Old Dec 29, 2009 | 09:23 AM
erbenson's Avatar
erbenson
Piraman - After having gone through multiple remans, I would agree with you. I eventually found a solenoid at a local electrical shop and they were good about testing the starter after installing the solenoid.
If anyone is in the Baltimore-Washington area, check out P&H Auto Electrics.
tjdad62
Feb 2, 2015 12:20 AM
Rich1953ard
Apr 28, 2013 10:34 AM
westroud
Jun 3, 2012 02:53 PM
hav24wheel
Jan 5, 2010 10:24 AM
SSdiesel
Jun 28, 2009 11:50 PM
