Sponsored by: Real Truck
Eratic Front diff engagment
Old Aug 25, 2009 | 08:59 PM
Clint77's Avatar
Clint77
I have a 2004 f-350 lariat 6.0l, roughly 245,000k. I was on a long trip 1200k, after 150k the front end started making a grinding noise, then it felt almost as if something was binding. I have replaced the stock auto hubs with warn heavy duties. Regardless I pulled the centres to see if it made a difference, it didn't. After the next 100k it stopped. Drove the rest of the trip with no issues, except the last 100k. Found a little trail went for a quick rip and started making the noise again. Got home, pulled the driver side hub assembly and found someone had tinkered and put the spacer washer inside the hub instead of between the hub assembly and knuckle seal. Have since replaced needle bearings and knuckle seal to no avail. Still sounds like front is trying to lock, when both hubs are locked there is no noise, any ideas????? driving me nuts. Any help would be appreciated.
Y2K1TON
1978 - 1996 Big Bronco
Mar 3, 2016 04:55 PM
crobotti
Apr 9, 2014 10:35 AM
lalevant
Jun 12, 2009 11:47 PM
Paul Dozoretz
Dec 28, 2008 07:19 AM
Bigtruckdriva
Apr 24, 2005 01:51 AM
