2wd to 4wd swap. what dana 44 axle to use
hey guys. First off, i am gonna say this. i aint gonna put my trucks body onto a newer frame. with that said, i need some help. I have a 1964 ford f100 that i want to convert to 4wd. It has leaf spring front suspension. My question is, wat yrs did ford use a leaf sprung front diff with the ford 5x5.5 bolt pattern with disc brakes. dont care to much about leaf spring pad placement cause i already know i'm gonna have to move them.
or maybe you should just convert it to 3/4 to front and rear. but you could also find a 3/4 ton dana44 and swap from the spindles out to get your 5 lug like crazy said. If i were you i would think about doing the coils up front from everything off of a late 70s f150. i have seen it done and seems to be fairly easy and rides awesome.
OFLM
03-09-2015 08:24 AM
hasteranger
04-27-2012 06:14 PM
