Not shifting into first?
Old Aug 25, 2009 | 11:40 AM
Gary E's Avatar
Gary E
its a 1997 2.5 liter with 5 speed stick. The engine is coming out today because it is toast. But it was having problems going into first gear. When I pull the tranny how can I inspect it to make sure its bad before I replace it? The tranny fluid was pretty thick for atf and black I would not be suprised if the lube place put gear oil in it. It only has 128k miles but its a pest control service truck, 12 stops per day carring about 6-700 lbs in the bed at all times.
What kind of fluid should I be putting back in the tranny synchromesh? regular atf?
Old Aug 25, 2009 | 07:41 PM
XLT2.5L's Avatar
XLT2.5L
I just always put Dexron/Mercon III atf in my transmissions and have never had a problem.
Old Aug 25, 2009 | 09:02 PM
Gary E's Avatar
Gary E
I got it pulled apart and its worn down to the wear bars and the input shaft bearing is toast. I am guessing those were my main culprits.
