Sponsored by: Real Truck
squealing when taking off
Old Aug 24, 2009 | 10:22 PM
dreammachine460's Avatar
dreammachine460
Question squealing when taking off
Ok guys I have a 2k F250 with 7.3 and six speed. When I put it in first, lo, or reverse and let the clutch out it squeals... I am thinking pilot bearing but not sure. There are no real performance issues except starting up steep hills. Has anyone heard this on there SD? If it is pilot bearing i think i can fix w/o sending to a shop. Any help regarding would be greatly appreciated!
Thanks Toby
Old Aug 25, 2009 | 11:36 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Are you sure the clutch plate isn't just worn out and the rivets are contacting the flywheel?
Old Aug 26, 2009 | 11:05 PM
dreammachine460
u may be right just don't know how to check...
Old Aug 27, 2009 | 11:14 AM
krewat's Avatar
krewat
Pull the inspection cover off the bellhousing and see if you have any metal filings laying around.
Or, get a helper to step on the clutch while you're under there, and see if you can tell if the flywheel is scored.
