squealing when taking off
Ok guys I have a 2k F250 with 7.3 and six speed. When I put it in first, lo, or reverse and let the clutch out it squeals... I am thinking pilot bearing but not sure. There are no real performance issues except starting up steep hills. Has anyone heard this on there SD? If it is pilot bearing i think i can fix w/o sending to a shop. Any help regarding would be greatly appreciated!
Thanks Toby
Thanks Toby
Pull the inspection cover off the bellhousing and see if you have any metal filings laying around.
Or, get a helper to step on the clutch while you're under there, and see if you can tell if the flywheel is scored.
