Sponsored by: Real Truck
Brake Problem? Please help!!!!
Old Aug 24, 2009 | 07:14 PM
Remmons's Avatar
Remmons
Angry Brake Problem? Please help!!!!
I am currently experiencing a problem with my brakes that is baffling me. I replaced calipers rotors and pads on the rear. I am now getting a squeal from the passenger rear wheel like a rotor is rubbing on something. I have tried adjusting emergency brake. It seems like the sound starts after hitting a large bump. It goes away at times but after a few more bumps it starts squealing again. If any of you have had this problem I would greatly appreciate any knowledge on it. I love this web site it has been so helpful in the past. Thanks again in advance!!!!!!
Old Aug 24, 2009 | 07:49 PM
Monster-4's Avatar
Monster-4
A little for detail would be helpful. Year, model, engine, drivetrain.
Old Aug 24, 2009 | 07:50 PM
kelly67's Avatar
kelly67
the anti rattle clips at each and of the pads have you checked those? and did you look very carefully for any worn spots of matel rubbing?
Old Aug 24, 2009 | 08:05 PM
Remmons's Avatar
Remmons
02 F-250 Crew Cab 4x4 Lariat V-10 3.73 I replaced the clips with the new calipers and and they don't seem to be rubbing anything. This problem all arised after finding two stuck calipers and which eventually lead to wearing of the pads.
Old Feb 27, 2010 | 11:06 PM
Remmons's Avatar
Remmons
Brake Problem Fixed !!!!
Yes, Thanks for replying to post. I think that I finally resolved my brake Problem after several attemps. I ended up replacing the brake hose on the passenger rear side. I also replaced hose from rear axle to metal brake line back to master cylinder as well as the metal brake line . I no longer hear the squealing. Just something to keep in mind if you are having a similar problem
