AFE bogus claims??
Old Aug 24, 2009 | 07:00 PM
sjwelds's Avatar
sjwelds
AFE bogus claims??
Hey I was on a website that sold AFE air intake products and they said that an AFE Pro-Dry S intake system would add 17 hp and 21 lb.-ft. of torque. To me that seems a little on the high side. Any input??
Old Aug 24, 2009 | 07:29 PM
JoSHN's Avatar
JoSHN
Not necessarily. If you replace an old clogged up filter with a new one that provides a little better airflow, you can gain 5-20 hp.
Now... you can get the same HP bump just by replacing the filter with a stock one as well.
Just keep that in mind.
Old Aug 24, 2009 | 08:48 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
their claims are true...with the following disclaimer
"A performance tuner was used in conjunction with the CAI to achieve the DYNO results shown"
just slapping a CAI onto the motor will do nothing to help increase HP/TQ. You have to tell the PCM that it is there, and have the PCM adjust accordingly.
a little bit of fakery that all of the companies use. Since you already have some tunes from 5-star tuning, I suggest you contact them and see what CAI they recommend...and tune for. Most N/A 5.4 motors can be pretty easily gotten to about 245-250 RWHP with a CAI/Exhaust/91 octane tune.
Old Aug 25, 2009 | 07:35 AM
sjwelds's Avatar
sjwelds
yeah he says to use s&b but that even with tunes for it one would only gain 5-10 hp mostly above 4000 rpm. i'm thinkin now i'll probably do the "gotts mod" that i've read about on here
Old Aug 25, 2009 | 02:16 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
good choice.
PHP has shown a +7 HP gain with tuning by removing the Factory Snorkel from the fender
The CAI's are nice and all, but they are only really good for noise. I'd buy another one in a heartbeat because I love that 4-barrel big block noise though.
Old Aug 26, 2009 | 06:38 PM
baitmaster's Avatar
baitmaster
I have one on mine, and didnt notice any perf dif. But I doubt I would notice 10 hp anyhow. hitting the freeway with passing gear sure sounds good with the magnaflow muff. But in town driving I wouldnt mind if it was a little quieter.
Old Aug 26, 2009 | 09:25 PM
sjwelds's Avatar
sjwelds
Hey guys I did the "gotts mod" that I've read about on here. I'm a welder and have access to aluminum so I used a chunk of aluminum pipe instead of plastic. That worked out great. Now I want to polish out the pipe for better underhood looks. Do you guys think I need to have Mike from 5star redo the tunes on it??
firecatab
6.4L Power Stroke Diesel
Aug 20, 2011 12:04 AM
shipp.28
Mar 28, 2009 10:12 AM
WorldCommander
Modular V10 (6.8l)
Oct 25, 2005 05:33 PM
96ford4x4turbodiesel
Jun 7, 2004 02:41 AM
