67 F600 VIN help?
Thanks in advance
Mark
F60BKA 19459
132 F602 M81 M F8
20000 150 3600 739652
Thanks in advance
Mark
F60BKA19459
132 F602 M81 M F8
F60 = F600 2WD
B = 300 1V I-6
K = Kansas City Assembly Plant
A19459 = 1967, assembled September 1966
132" Wheelbase
COLOR code missing
F602 = F600 2WD / 20,000 lbs. GVWR
M81: M = Medium Beige Petticrush Vinyl & Medium Beige Leeds Pattern Woven Plastic // 81 = 81A Standard Cab
M = Clark Model 250VO 5 Speed Direct or Dana-Spicer Model 6452A 5 Speed Direct *
F8 = Eaton Model 13802 2 Speed Rear Axle / 6.63-1/8.81-1 / 15,000 lb. Rear Axle Capacity **
20,000 lbs. Gross Vehicle Weight Rating
150 net HP @ 3600 RPM
739652:
73 = Salt Lake City Ford District Sales Zone Office, where the original selling dealer ordered the truck from.
9652 = Domestic Special Order number. The truck was special ordered by the original purchaser, not "bought off the lot."
Since there is no COLOR code, one reason it was ordered special is because it was painted a non standard color.
* Ford used the letter M in 1966/67 for both these 5 speed transmissions.
** Since there is only a rear axle code (F8), the front axle that is standard equipment for a 1967 F600 is rated at 5,000 lbs. capacity.
If there was a front axle code, there would be an additional letter after F8. Ford did it this way thru 1969. 1970 and later: All F500 and larger trucks have a front axle code.
Brakes (sigh
) Looking up brake parts for these trucks is a PITA!Thankfully you came up with useful information.
Rear Brakes: F600 / 15,000 lb. rear axle capacity / drum measures 4 1/4" across the flat = Prolly 15" x 4" / These are the other choices: 15" x 4 1/2" or 15" x 5"
Front Brakes: F600 / 5,000 lb. front axle capacity / 14" X 2 1/2"
Brake parts availability. Most of the parts can be found, except the front & rear brake drums, which are very hard to find new...or used.
C3TZ-1425
PO25A 11396
Thanks
