Kick Down Rod Help
Old Aug 23, 2009 | 12:26 PM
builtfordtough13's Avatar
builtfordtough13
Kick Down Rod Help
I just added a edelbrock 1406 carb and performer intake to my 78 F-150 w/ a 302 and c4 and when I went to install the kickdown rod from the transmission back to the carb it wouldn't work, totally wrong postition. Has anyone had this problem?? Any help would be appreciated. Thanks!!
Old Aug 23, 2009 | 05:49 PM
fmc400's Avatar
fmc400
MSEE
Edelbrock carburetors aren't set up to accept Ford kickdown linkage from the factory. You'll need a kit to make this work.
Old Aug 23, 2009 | 06:46 PM
builtfordtough13
Umm.. thanks, what kit do you reccomend.
Old Aug 23, 2009 | 07:10 PM
fmc400's Avatar
fmc400
MSEE
Does your '78 have a throttle cable or linkage? I can't remember when the switch was. I was thinking you had a linkage, but in case you have a throttle cable, Edelbrock #1483 is an adapter that should work (according to them, not me). Take a look at the product info:
http://www.edelbrock.com/automotive_...throttle.shtml
If not, Lokar is the way to go.
Old Aug 23, 2009 | 07:25 PM
hp246's Avatar
hp246
YEp, Edelbrock makes a kit. The other option is an aftermarket Kickdown cable. I think the kit is alot cheaper.
Old Aug 23, 2009 | 07:51 PM
ladelld33's Avatar
ladelld33
hey i got that kit plus the other bracket that goes with it and i still can't figure out how to make it work
Old Aug 23, 2009 | 08:19 PM
fmc400's Avatar
fmc400
MSEE
You should contact Edelbrock tech support for that question because the odds of someone with your same setup using that exact kit in this one forum are fairly low.
Old Aug 23, 2009 | 08:29 PM
builtfordtough13
Thanks I guess I have to get the aftermarket kickdown cable, I too got that kit and it doesn't work. Oh well. Thanks for the help!
Old Aug 23, 2009 | 08:34 PM
hp246's Avatar
hp246
You bought the Kickdown cable from Lokar and it doesn't work? I have that system, and it is really easy to install. Diretions that came with it were great. All you have to do is install, adjust so that it is when butterfly is wide open, the kickdown is engaged.
Old Aug 23, 2009 | 08:52 PM
builtfordtough13
No I bought that edelbrock thing part number 1483. I will be buying the lokar kit. Thanks
Old Aug 23, 2009 | 08:58 PM
hp246's Avatar
hp246
Sorry,
I misread your earlier post. Before you buy the Lokar kit, go to their website. O'm pretty sure they have their direction posted. Good luck. Can get kind frustrating at times.
jetrinka
Jan 27, 2015 07:49 PM
jmm
Sep 7, 2011 08:09 PM
salf100
17
Aug 1, 2009 12:56 PM
mkarns
May 31, 2005 07:39 AM
