Tie Rod Help Please...
Old Aug 23, 2009 | 11:26 AM
PADoubleX's Avatar
PADoubleX
Hi
'02 Excursion 4WD V-10. I just replace the passenger tie rod end, the one that connect steering knuckle to steering knuckle.
The rod (center link?) that connects the pitman arm to the tie rod is pretty sloppy. I'm going to replace that too. What is this part called?
Is the tie rod that connects the steering knuckles together the inner or the outer?
Thanks, need to get this done today.
Old Aug 23, 2009 | 03:10 PM
PADoubleX's Avatar
PADoubleX
Answer
The outer tie rod runs from steering knuckle to steering knuckle.
The inner tie rod run from the pitman arm to the out tie rod end on the passenger side.
