Quick ? on tires...
Old Aug 23, 2009 | 09:52 AM
timbersteel's Avatar
timbersteel
Quick ? on tires...
I have a '92, F-150, 4x4, I6, with 8.8" rear axle, 3.08 ratio. I was wondering If I can run the 31x10.50R15 tires.
I would like to go up another tire size for look, traction, and stability.
Any ideas would help.
Thanks,
Matthew
Old Aug 23, 2009 | 10:21 AM
A1C DiMaggio's Avatar
A1C DiMaggio
you should be able to fit 31s without a problem, but if you go any bigger you will need a lift. 32s require a 2.5" lift or they will rub.
Old Aug 23, 2009 | 11:55 AM
White 97 xlt's Avatar
White 97 xlt
If you intend to haul anything, tow anything, or have a drivable truck you will need to change the gearing if you go to much bigger tires....
Old Aug 24, 2009 | 07:43 AM
timbersteel
White 97 xlt, "...will need to change the gearing if you go to much bigger tires.... ", so it isn't a good idea then? I don't want to go any bigger than that. what would you recommend for a tire size? I'm just sick of the 235's I have on it right now with a 15" rim.
as for the gearing, mine to change would be really phun!! Pun intended! From what I have read, I would also have to change the gearing in the front, correct? That would be the "phun" part of the job.
Matthew
Old Aug 24, 2009 | 09:59 AM
A1C DiMaggio
Matthew
if you do go with larger tires, it would be best to change the gears in both front and rear. if you only want a mild lift, i would look into a 2.5" with 31" tires. it would look pretty good and, depending on how you use the truck, you may not need to change the gears. for example, if you haul/tow often, changing the gears would help with gas mileage and moving the load.
here is a link to a gear ratio chart: http://www.4lo.com/calc/geartable.htm
good luck
Old Aug 24, 2009 | 12:20 PM
skaterbro's Avatar
skaterbro
You won't have any problems running that size tire on the stock rims and suspension. That's all i've ran since i bought the truck.
