Long time reader with only a few posts here, but have leaned alot here. I have a early 99 7.3. Truck is used for towing 90% of time but only average 8K miles a year. Truck does have 140k. New tranny 3k ago. The last 6 months I have noticed that at initial start up it seems to take a long time to build power. For instance yesterday I started truck and let idel about 1 min. I needed to back the truck up a slight incline to hook up to a trailer. Truck took a long time and turbo had to really spool up before I could make it up incline. I do not notice this loss of power if for instance the truck has been driven several miles. Truck tows horse trailer fine. Ive noticed this a few times and when it does it, it can be when in reverse or drive. But give the truck 5-10 min to warm up after sitting for a few days and it is fine. I do plan to take truck to diesel shop this fall just for a once over for general maintenance. Just wondering if something I may be needing to look at or at least the thoughts of others. By the way my son has a same truck in 95 and his does not have the same slow warmup time that mine requires. Thanks for any ideas.
Nope. Cant be lack of oil change. Oil changed at 4k miles and last change was less than 800 miles. I had to back truck up same incline this pm after truck had be run for 20 miles or so. No problem, lots of power, no hesitation or excessive turbo spool. I only notice the lack of power if the truck has been sitting for a few days. I will start, even in summer, let idel a minute or so and when I back truck up incline to hook up to trailer it just seem like loss of power, turbo has to wind up. Does not feel like tranny is slipping. Its hard to explain. Sorry this is best I can do. only mod I have is kwik filter and have had that for at least 4 years. Tell me about IPR not familiar with the acronym. Willing to listen to any advice. Thanks
This tells me that the engine is developing the power OK, but that something is binding.
I think you have a transmission problem that is causing it to engage two gears at once, and making it seize up.
My first thought was EBPV as well...someone mentioned it should activate below 40 degrees so if you are somewhere that got that cold what you could be experiencing is normal 7.3L behavior...especially if it resolves itself after warming up.
