waterpump
Old Aug 26, 2009 | 04:07 AM
proudtruck's Avatar
proudtruck
Unhappy waterpump
Today my waterpump went out so it has to be replaced its my first time to do anything to my truck is it hard do i need any special tools where can i get a good waterpump are autozones alright or do you recommend something other than autozone. I'm not new to mechanic work I work on my 5.0 alot
Old Aug 26, 2009 | 04:29 AM
Stewart_H's Avatar
Stewart_H
There's a ton of info to be had by using the search button, but even that aint necessary because there's a current thread where someone just asked the same question.
Instead of regurgitating the info, here's the thread for ya!
https://www.ford-trucks.com/forums/8...p-removal.html
Stewart
PS - Ya gotta love the venerable pushrod Fords. I have a '90 5.0 myself.
Old Aug 26, 2009 | 05:41 AM
Supercab's Avatar
Supercab
Wink
Plus 2, Check the other threads and/or do a search, get a NEW AIRTEX pump from Northern auto parts on Ebay, great folks and service? don't waste your labor on a reman. pump!
Old Aug 26, 2009 | 07:12 AM
greagin's Avatar
greagin
got mine from NAPA for $150, new. i would also advise to get a new 203* thermostat ($40+/-) and a new thermostat housing ($23+/-) AND its a good time to replace your Upper radiator hose to a hose that goes around the serpentine belt instead of through it ($12+/-) AND may as well replace your lower hose ($12) also instead of waiting to dump a lot of antifreeze out when it fails. Just my .02.
Old Aug 26, 2009 | 09:43 AM
PaysonPSD's Avatar
PaysonPSD
For reference here's the ford part for upper radiator hose.
LINK
Old Aug 26, 2009 | 11:52 AM
mind's Avatar
mind
Gonna be doing a water pump and fan clutch this weekend. I got my water pump from northern auto and its a new Airtex unit, then I pucked up a Hayden fan clutch from rock auto. Do a search for more info, also there is another video on how to do a water pump I think its over at thedieselstop.
Old Aug 26, 2009 | 12:03 PM
greagin's Avatar
greagin
its not a bad job at all, just make sure you have a pulley holder tool. if not, you will learn some new words. also, the fan hub nut is a 47mm or 48mm, i forget exactly which one. if you dont have a fan wrench that big a pipe wrench will also work
Old Aug 26, 2009 | 12:29 PM
brian42's Avatar
brian42
Veteran: Navy
You can get the thermostat and housing at:
Housing: http://www.dieselsite.com/index.asp?...ROD&ProdID=188
Thermostat: http://www.dieselsite.com/index.asp?...ROD&ProdID=186
The upper radiator hose that goes around the belt is for the dual alternator setup.
The billet housing doesn't mate well with the less than flat cast iron block. I cleaned all the surfaces and put a bead of RTV down before bolting the housing to the block (don't ask how I figured this out ). I also went and bought a new lower housing too since I had a small leak coming out of mine.
Old Aug 26, 2009 | 08:45 PM
greagin's Avatar
greagin
my pump came with a new lower housing. i also used only the crappy rubber oring and had a leak so i took it back off, ran a healthy bead of permatex waterpump sealnat around it and it seems tight as a tick now. no leaks at all.
Stinky1
Dec 21, 2012 11:43 PM
Stinky1
Dec 18, 2012 02:31 PM
jdmef9
Nov 4, 2008 10:43 PM
cryinshames
Mar 12, 2006 12:23 PM
Vinford
Jul 2, 2005 07:07 PM
