Checked out the truck. Looks great, started right up, very clean, 117K miles, Almost no rust on the underside, but I revved the motor and it wound up but when going back down to idle it died. It did this every time after revving. There is a vaccum solenoid actuating an arm on the exhaust portion of the turbine so I am not sure if it is a wastegated turbo. The ATS turbo was purchased in '97 at around 80K miles. I thought it maybe a turbo issue causing it to die after revving but wanted to see if anyone has some insight into the cause of this issue.
Take the fuel filter off, dump out the fuel then fill it with Automatic transmission fluid. Run it for about thirty seconds then shut it off and let it sit for a couple of hours. Now take it for a drive and see how it does. There is a govenor linkage inside the IP that can get sticky which causes the IP to not recover to idle fast enough and it dies. Use the search you will find several posts with people that have had this same problem and fixed it with ATF or Seafoam.
I'd use Diesel Kleen or some other cleaning solution to free the governor in the IP, ATF works I guess but I'd prefer something that was made for that purpose.
And the "vacuum solenoid actuating an arm" is actually operated by boost pressure.
Waste gate actuator is a better name.
There is a spring inside that holds the waste gate closed.
As boost pressure increases in the intake, the spring is overpowered by that pressure to open the waste gate allowing exhaust gasses to bypass the turbo and limit boost pressure.
[quote=78sharpshooter;7857469]Checked out the truck. Looks great, started right up, very clean, 117K miles, Almost no rust on the underside, but I revved the motor and it wound up but when going back down to idle it died. /quote]
My truck, although not turbo'd, did the exact same thing (died after revving) when I was looking at buying it. Dave Sp. suggested the filling of the new fuel filter w/Diesel Kleen, and it worked like a charm! It stopped dying after only about 25 miles of driving, and has driven fantastically for almost 50K miles now.
