1989 Ford E350 will not start, possible EEC Problem
Old Nov 2, 2013 | 01:56 PM
  #46
subford's Avatar
subford
21 & 24 are OK, they are there because the engine was cold and the air temp was below 50*F.
You may have a problem with the TPS, code 63.
Your EGR valve is also not closed, may be dirty and need cleaning, code 34.
85 is the CANP solenoid and it is not causing your running problem but we can address it after you get it running.
So clean the EGR valve and make sure it will close as it is open right now. Also check its plug and wiring on its sensor on top.
The TPS may also be causing the dieing issue. Check its plug and wiring.
Old Nov 2, 2013 | 02:32 PM
  #47
chris herman's Avatar
chris herman
I have no power at red wire on injectors with key on also noid light not lighting up during cranking have power at red wire on relays passenger side of fender with I belive are starter and rec relay
Old Nov 2, 2013 | 02:33 PM
  #48
chris herman
I meant eec relay
Old Nov 2, 2013 | 02:45 PM
  #49
subford's Avatar
subford
The red wire runs from the EEC Power Relay to all the injectors, fuel pump relay, computer and other solenoids and sensors.
The NOID light will not flash with no power on the red wire.
You have power on the red wire at the computer or you could not have checked the codes.
Sounds like there is an open in the red wire going to the engine from the fender harness.
Old Nov 2, 2013 | 02:48 PM
  #50
subford's Avatar
subford
It should be wired something like the diagram below:
Old Nov 2, 2013 | 03:25 PM
  #51
chris herman
I will check red wire from relay to engine. In one post u said causing it to die the engine will not crank at all unless starting fluid sprayed into breather. Just so we're on the same page. Thanks again for you're help.
Old Nov 2, 2013 | 05:00 PM
  #52
chris herman
subford
I unwrapped efi wires from relay to motor found no break in red wire. still injectors not working. dose the main computer control the injectors? computer is the only thing I've not cleaned or replaced that I can think of . can it be bad but still able to read the codes form it ? fuel system seems to be working except injectors.
Old Nov 2, 2013 | 06:53 PM
  #53
subford's Avatar
subford
The computer grounds the injectors to fire them but the power to them comes from the power relay.
Yes if the clock is not running in the computer I think you might be able to get codes but the injectors would not fire. But if the clock is not running then the fuel pump should run all the time the key is on.
Old Nov 2, 2013 | 07:33 PM
  #54
chris herman
Right strange for sure pump cuts off. Don't no if it matters but it has an aftermart RV 68 gal gas tank installed . Also the air deverter black unit on top of motor on passengers side of motor was clicking blowing air out the vent holes on it. I think it has a check vale in it. I've worked very little on fords except the ol 300 sizable years ago. I have 4no diesel trucks and 3u diesel air compressors.work on all them but this is blowing. Guess will try computer orillys got them 75bucks. .what do u suggest if it was you?
Old Nov 3, 2013 | 07:45 AM
  #55
subford's Avatar
subford
I would find out why there is no power on the red wire at the injectors with the key on before I would do any thing else.
Is there any sign of Rodents eating wiring?
Old Nov 3, 2013 | 08:47 AM
  #56
chris herman
No sings. Of rats just drove its 200good miles replaced fuel reg. Old one was bad guess injectors weren't working than was sucking fuel from vaccine line off fuel pressure reg to run
how many volts should be on red wire from relay
Old Nov 3, 2013 | 08:57 AM
  #57
subford's Avatar
subford
You should have battery voltage on the red wire (12-13~ volts with the key on).
The power relay is just an off & on switch between the battery and the red wire operated by the ignition switch.
Old Nov 3, 2013 | 09:47 AM
  #58
chris herman
subford
I think I will run a 12 volt wire from battery to red injector wire see if they will fire
Old Nov 3, 2013 | 10:07 AM
  #59
chris herman
from what I under stand red wires at injectors stay hot when switch is on than computer grounds them as they need to open and there should be 12 volts at red wires at the injectors with switch on ?
Old Nov 3, 2013 | 11:25 AM
  #60
subford's Avatar
subford
This is true.
