No shift trans
Old Aug 22, 2009 | 03:25 PM
Motox745's Avatar
Motox745
No shift trans
Got in my 2000 F-350 automatic, with 178 thousand miles on it, this morning going on a trip the the motocross track. Stopped in town to get ice. Put the truck in gear and nothing, no go in any gear except reverse. Any ideas what happened and how to fix it? Thanks Ron
Old Aug 22, 2009 | 05:31 PM
farmdad's Avatar
farmdad
Probably the bushing on the steering column that the shift shaft goes through has gone away. When this happens, the linkage is too loose to shift right. It is a $5 part at the dealership for a new bushing and you should be good to go. You will have to remove the cover over the steering column to change it but it isn't a hard job. This would be a cheap fix if this is the problem.
ron young
New Member Introductions
Feb 12, 2014 12:40 PM
90-B2ron
Bronco II
Jun 1, 2012 07:39 AM
megawatt00
17
May 8, 2010 01:13 PM
ron's power stroke
28
Mar 15, 2008 08:50 AM
99350Ron
Mar 11, 2008 12:18 PM
