Sponsored by: Real Truck
Intermitent Battery Light
Old Aug 22, 2009 | 10:28 AM
Mustangoutcast's Avatar
Mustangoutcast
I have my tuner set to show Battery Voltage. I had a battery light come on, NO DTC's Thrown, Took Alternator out and had checked, Tested at 15 Volts. Belt checked good, Batteries ?, so installed 2 new NAPA Bat's, Battery light is still an intermittent Problem. When Bat light comes on Bat Voltage drops to between 11.7-12.2 when Bat light goes out Bat. Volt reads from 13.2-14.0 . Some times seems to be rpm related, but other times means nothing. At times I hear a high pitch sound, (other than Turbo). I get home jump out and put volt meter across battery and get between 12.2-12.5 . I am not made of money and can not afford to throw money at this thing. Any help would be appreciated. Thanxs
Old Aug 22, 2009 | 04:26 PM
KGB's Avatar
KGB
What is the vehicle year, engine ???
Old Aug 22, 2009 | 05:33 PM
Rongold's Avatar
Rongold
Unhappy Battery light
An intermittant battery light is almost always a sign that your alternator is starting to go bad.
RON
Old Aug 25, 2009 | 03:22 AM
Mustangoutcast
Is 99 7.3 diesel
Old Aug 25, 2009 | 03:23 AM
Mustangoutcast
makes sense i have it checked at parts place and it checks ok
Old Aug 25, 2009 | 08:02 AM
senix's Avatar
senix
yup...time for a alternator, just a matter of time when it goes out completely.
Old Aug 25, 2009 | 10:36 AM
Neil_E.'s Avatar
Neil_E.
If the alternator test is valid, the only other cause is likely a bad connection. Check all your cables and ground straps for corrosion. Some vehicles can have a problem where the positive cables are connected together (pairing diesel batteries). Etching over time will degrade the connection and can cause large intermittent voltage swings. The big draw from cranking temporarily welds the connection point together and it seems OK for a while. When it gets bad enough the engine will stop for an instant then catch again.
These events don't normally make the alternator light come on, they just cause voltage swings. A flaky alternator light is usually from a bad diode.
Old Aug 25, 2009 | 10:59 AM
Mustangoutcast
Diode being in the Alternator itself? I believe the regulator/rectifier is inside alternator on this truck right?
Old Aug 25, 2009 | 07:17 PM
BobbyDiesel71's Avatar
BobbyDiesel71
the 99 had the older LEAD version battery cables. They can be old and wornout. Check all connections. Consider upgrading to the newer 01 style SS connectors. The batt post connector on the passenger side gets loose and doesn't tighten again very well, plus it holds the + wires for both batterys
Old Aug 25, 2009 | 07:26 PM
KGB's Avatar
KGB
This is what I had on my 99 F250 SD 5.7L . Check in line fuse link from alt to starter solenoid ,it is just before the solenoid. Mine had corrsion problem under heat shrink seal.
This looked good from the outside untill I removed seal to find problem.
This was done 4 days ago on my truck.
good luck.
