You can use your 302s flywheel as long as it is original to the truck, they changed the balance in the 80s and the newer ones won't work. Sorry 302 manifolds will not fit, bolt pattern is different and the ports are about half the size. What years is this motor? Are you sure it is a C and not an M or a W?
-Johnboy
The Windsor is easier. They're much more similar to the 302. The exhaust manifolds interchange between the 302 and the 351W. But you still need new brackets.
