engine stumbles when humid or raining
Old Jan 25, 2010 | 12:35 PM
Kody Brown's Avatar
Kody Brown
I hope you find out! My 06, 6.0l turbo Lariat last month did about the same. Temp was 40 been snowing/raining came off the freeway slowed to 40mph and it started revering up without throttling and idling ruff at the stop light I noticed I had no turbo pressure. Ran this way for about 10 minutes. Stopped at a friend’s house for couple of hours. Went out started up just fine and has not did this since?
Old Feb 28, 2021 | 08:50 PM
Eric Moore's Avatar
Eric Moore
Originally Posted by nlfireblade
I have checked all electrical connections that I could see. I always put dielectric grease on electrical connections(just bought a quad and unplugged every connection and filled with dielectric grease before I even rode it lol). What I find odd is that this problem occurs after it has rained and the ground is dry before I drive. Not much can get wet in this circumstance. It happens as soon as I start the truck and haven't moved it yet. Very annoying!
I Have same prob once in a while it will run so rough it gives a misfire in number 6 code n I delete it but I got new coils battery o2 sensor mine is a 98 4.9
Old Feb 28, 2021 | 11:24 PM
Lime1GT's Avatar
Lime1GT
You should fix it before the catalytic convertor fails.
gallgood
6.2L V8
Jun 7, 2011 07:23 AM
BigAlsPSD
41
Feb 7, 2011 05:54 PM
tempter927
May 8, 2006 10:02 PM
bizz60
Nov 18, 2005 12:14 PM
