6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Cuts out a 80mph
Old Aug 21, 2009 | 07:15 PM
KIOTI's Avatar
KIOTI
Cuts out a 80mph
OKay so I was going somewhere yesterday and need to get there!
My trucks starts to buck and won't go any faster than 80mph.
Please don't tell me about my speed just tell me if the truck is defueling and if the factory shuts these off at this speed?
I do not have any mods done?????
Old Aug 21, 2009 | 07:47 PM
LJC's Avatar
LJC
You'll need to indicate what truck you have F250, F450... If I don't mistake the F250 is limited to 94 miles/hour..
Old Aug 21, 2009 | 07:49 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
From the size of the wheels in your avatar, I'm gonna go with you have a 450. With the detuned engine and the 4.88s, you probably are hitting some kind of rev limiter/ governor in the PCM.
Old Aug 21, 2009 | 07:52 PM
R-T0r21on's Avatar
R-T0r21on
Yep. A F-450 cuts out at about the low 80's mph due to ford tuning for the tire speed ratings.
Old Aug 21, 2009 | 08:12 PM
gwcon's Avatar
gwcon
I thought the rev limiter was to protect the engine R-TOr21on. Where did you hear it was for the tires? Just curious.
Old Aug 21, 2009 | 08:21 PM
powerstroke72's Avatar
powerstroke72
Rick, your truck has the 4.88 gears if I remember correctly. If this is the case, it's programmed from the factory to for fuel cutout at 82 MPH on the F-450s. So it is governed, so to speak, to 82MPH.
Old Aug 21, 2009 | 08:25 PM
texastech_diesel
Token Redneck
Lots of 19.5" tires (and 22.5" and 24.5" for that matter, since we're talking commercial tires) are rated by the mfg. to have a 75-80 mph speed rating. I don't know how likely a tread sep is on something as light as an F-450, but there's probably a nasty liability problem for Ford somewhere in this governor
Old Aug 21, 2009 | 08:27 PM
powerstroke72
Good point Bryan. That's probably the thinking behind the speed limiter on it.
Old Aug 21, 2009 | 08:28 PM
senix's Avatar
senix
yup. speed limiter. only way around is it going to be a programmer, On a 450 I would not advise it.
KIOTI's Avatar
KIOTI
Just as I thought my 450 has training wheels on it
Hmmm..just one more reason I need a Spartan
Old Aug 21, 2009 | 08:30 PM
powerstroke72
How has it been running? Did you get it straightened out from the problems you'd been having?
Old Aug 21, 2009 | 08:38 PM
KIOTI's Avatar
KIOTI
It has been running real good lately...9,500 miles on the clock we changed the oil and I thought I didn't get the oil plug tight but after checking it I still see a drip of oil on the floor.
I will have to get it up on the lift and inspect it further.
I ran out to state college yesterday and I ran it real hard well it would have been harder if I could have got a little more mph average around 11.2 on the lie-o-meter
Still could use a little pulling power when loaded.
Another good reason for a Spartan
Old Aug 21, 2009 | 08:41 PM
powerstroke72
Sounds good. And, your MPGs don't sound as bad as they had before either. Spartan tunes should help you out all the way around though.
Old Aug 21, 2009 | 11:40 PM
SpartanDieselTech's Avatar
SpartanDieselTech
Former Vendor
We can get rid of the pesky limiter- they will handle speeds faster than you'll likely find a need for with it gone.
As for the power and mileage....
Old Aug 23, 2009 | 09:41 PM
jboczar's Avatar
jboczar
F250s & F350s are governed at 95 mph, F450s and F550s are governed 81 mph. FYI the truck also sets a continuous memory code (not a cel) so technicians can know if you have been driving up against the limiter.
Fastfwd
Oct 23, 2018 08:52 PM
T.C.SATTERFIELD
New Member Introductions
Mar 10, 2017 02:06 PM
Mikeman
Sep 7, 2016 11:44 PM
Phil Fleming
Jul 11, 2016 07:30 PM
scott fincher
Jul 9, 2011 12:45 PM
