how much fluid for e4od
Old Aug 21, 2009 | 09:55 AM
wildstang's Avatar
wildstang
VT Chapter Ldr
I want to change the fluid and flush the torque converter but not sure how much I will need to buy. At the same time I will probably put in an aftermarket cooler. I am probably going to get the Amsoil fluid. The manual says 16.2 quarts but it does not say if that includes the torque converter or not. Thanks.
Old Aug 21, 2009 | 10:24 AM
JasWood's Avatar
JasWood
I just did mine and it took 16 qts. plus however much your new cooler holds.
Old Aug 21, 2009 | 10:34 AM
Brown Falcon's Avatar
Brown Falcon
I believe you'll need between 16-18 quarts if you are draining everything. Just depends on how much you can get out of it...
jim6346
Dec 10, 2014 05:28 PM
joewaldner
Jul 22, 2010 10:05 PM
stroked 347
Jul 31, 2008 11:39 AM
ferguson777
Apr 21, 2008 07:34 AM
QBall
Dec 28, 2003 02:26 AM
