help with diagnostic's
Old Aug 21, 2009 | 01:20 AM
aaronlaaron's Avatar
aaronlaaron
93 turbo idi
5spd
335000kms
low compression on one cylinder
high oil consumption
oil in the rad
white smoke (anti freeze) on start up and when going down hills
high etg's
new turbo
new injectors
new cdr
what could my problem be??
Old Aug 21, 2009 | 02:22 AM
David85's Avatar
David85
What cylinder is low? Is any pressure building in the cooling system? typically it pushes coolant or foam out the recovery tank if it happens.
Most likely a head gasket, but too soon to really say 100%.
Old Aug 21, 2009 | 07:26 AM
bilder12's Avatar
bilder12
could be several problems at one time.
low compression and high oil consumption could be blown head gasket, cracked piston.
oil in radiator could be head gasket, oil cooler seals or oil cooler tube(s).
anti freeze smell at start up could be blown headgasket, cracked head, hole in cylinder from erosion.
high egt could be too much fuel or plugged air filter.
2diamondfarm
May 22, 2014 03:14 PM
jlh542
Nov 6, 2013 01:33 PM
High Binder
6.7L Power Stroke Diesel
Nov 8, 2010 07:01 PM
6LPSD
Apr 13, 2008 07:13 AM
