High Idle
Old Aug 20, 2009 | 07:02 PM
Major94's Avatar
Major94
Exclamation High Idle
Ok guys for the last few days, every once and awhile the truck ( a 95 f 350 7.3 psd) decides to go into a high idle mode on start up. And I dont have a high idle kit or any kind of performance chip.
But it only does it maybe 2 out of 10 times starting it. It goes upto maybe 900 rpm then back down to around 500 rpm.
Any help thanks.
Old Aug 21, 2009 | 05:32 PM
Major94's Avatar
Major94
Doesnt anyone have ant ideas???
Old Aug 21, 2009 | 07:11 PM
gt8684's Avatar
gt8684
when you start the truck and it jumps like that, is the truck cold? or does it do it randomly even once at operating temp?
Old Aug 21, 2009 | 07:18 PM
Major94's Avatar
Major94
It does it randomly. I mean I went down the highway, got to my shop and shut it off. Came out maybe 5 mins later and it did it.
Old Aug 21, 2009 | 07:25 PM
gt8684's Avatar
gt8684
have you checked the basics? fuel pressure, air filter, fuel filter? i usually change all the expensive parts just to find out it was something cheap causing the problem... you have any mods done on the truck?
Old Aug 21, 2009 | 08:26 PM
Major94's Avatar
Major94
Not at this moment. I do run power station supplement. Thats it... We will check all the basics later this week. Moms car needs cv joints tomorrow so we will be busy.
Old Aug 22, 2009 | 07:20 AM
wmiller's Avatar
wmiller
They are designed to do that when cold from the factory if i recall. If i had to guess you have a sensor going bad telling the computer thats it colder than it actually is. Not sure whick sensors are tied to it but someone should come along that knows. I think it the EOT sensor and one other
I would have a scanner put on it and check for any codes. You may even fiind anonther issue you didnt know about
Iron Port
1978 - 1996 Big Bronco
Jun 26, 2017 03:35 AM
toobzrn
Jan 19, 2016 11:20 AM
idle
Escape & Escape Hybrid
Jun 29, 2014 09:39 AM
plumbstar
Modular V10 (6.8l)
Feb 12, 2014 08:58 AM
Franko72
22
Oct 5, 2012 01:45 AM
