Sponsored by: Auxito
Front Shake/Vibrate
Old Aug 20, 2009 | 12:53 PM
backdraft529's Avatar
backdraft529
Front Shake/Vibrate
i have a 1997 ford f-150, V6, 4.2 L truck. when i go above 40-45 miles per hour, my front shakes something fierce. what could this be? tie rod ends, ball joints, what? those are the 2 things i was already told. any other ideas?
Old Aug 20, 2009 | 03:57 PM
Ron W.'s Avatar
Ron W.
Have you rotated you tires recently? Has one of the tires thrown of a wheel weight and is now out of balance? How many miles on the truck? 2wd. or 4wd.? have lower ball joints been replaced and if so how many miles ago? Are the front sway bar links OK?
Are you sure it's a front suspension problem?
I know this isn't much help but to many options to pick from and people could guess all day.
Old Aug 20, 2009 | 04:08 PM
MikeB 88's Avatar
MikeB 88
Same thing happened to me when I had my '88 F-150. Turned out both "lubed for life" ball joints were totally worn out. Replaced both with one that I had to lube and never had a problem again. My vibrations were at the same speeds as yours, felt the truck was going to come apart.
Old Aug 20, 2009 | 05:32 PM
galaxie641's Avatar
galaxie641
Is the shake in the steering wheel, seat, floor or whole truck? Does hitting the brakes do anything for it?
Old Aug 20, 2009 | 09:56 PM
backdraft529
i haven't rotated the tires. i believe the wheel weights are still on. it only has about 1200 miles because its a new engine. its 4wd. the ball joints were replaced about 6 years ago. the passanger side sway bar was jingling because it wasn't put on right but i did tighten it up but maybe i got it too tight. i will loosen it up a little. not totally sure its a suspension problem no.
the shake is from the steering and when i apply the brakes and slow down then it stops once i decrease in speed.
Old Aug 21, 2009 | 07:36 AM
MikeB 88's Avatar
MikeB 88
That's exactly what my '88 F-150 did. Started shaking violently, hit the brakes to slow down to around 30 and the shaking went away. I might recheck the ball joints. When our Charger develops a front end shake, even though it's not violent, it means tire rotation time.
Old Aug 22, 2009 | 11:40 AM
OkLaHoMaF150's Avatar
OkLaHoMaF150
My 2001 Screw is doing the same thing. Only the steering wheel shakes between 35-45mph and goes away after you get above 50. I'm thinking it's BJ time.... My truck has 158k miles on it and I don't know the previous owners work history so it may be the factory BJ's.
Old Aug 27, 2009 | 07:53 PM
green 1969 f100's Avatar
green 1969 f100
I just acquired a 2000 with similar problem. After all ball joints, bushings and tires were replaced, it drives like new.
Old Aug 27, 2009 | 09:59 PM
ubereal2's Avatar
ubereal2
Get a good look at the tires....... Feel the tread for un-even wear. If you can get them ballanced, watch the tires while there on the ballancer. See if they are running straight, or are they hopping. Are they A/T tread? They have to be rotated atleast every other oil change.
I've been doing this a long time (for a living) as an alignment tech, passenger car, light trucks, and heavy equiptment, 18 wheelers, Firetrucks all of em' for almost the last 10 years. Check tires, or just rotate them to the rear and drive em'....
Bob
Old Aug 28, 2009 | 11:12 AM
MikeB 88's Avatar
MikeB 88
Bob
Would out of balance tire cause a violent shake? When it's time to rotate tires on our Charger, it develops a mild shake. But nothing that makes it feel like the car is falling apart.
muth_33
Oct 1, 2025 12:29 PM
jmccracken1214
18
Dec 9, 2016 11:19 PM
SatinBlack03
May 4, 2015 06:53 PM
agmech2
Jan 17, 2011 11:58 PM
MTENIENTE
4 Cylinder Engines
Dec 7, 2005 08:31 AM
