Craigs list find
Old Aug 20, 2009 | 11:48 AM
just another truck's Avatar
just another truck
Craigs list find
http://detroit.craigslist.org/mcb/pts/1318088126.html
Give me a PM if you need me to go look!!
Old Aug 20, 2009 | 11:55 AM
stroken's Avatar
stroken
I just PM'd you about the rear glass, is it the rear sliding window or like the paice that goes in the door.... Iam hoping rear part of the cab.
GREAT FIND!
Old Aug 20, 2009 | 11:57 AM
superduty4x4's Avatar
superduty4x4
Someone better scoop up that trans cooler...
Old Aug 20, 2009 | 12:01 PM
just another truck
I have just sent off a email to the guy, so get me a list..
Old Aug 20, 2009 | 12:08 PM
dannyboy7.3's Avatar
dannyboy7.3
$50 for the trans cooler? I would like dibs on that if it's in good shape. Good find!
Old Aug 20, 2009 | 12:25 PM
strokersace's Avatar
strokersace
Great find Pat. Pm sent!
Old Aug 20, 2009 | 02:19 PM
megawatt00's Avatar
megawatt00
Nice find Pat the IC is only $100 if I had the extra. Can't give you much deserved reps gotta spread them around/
Old Aug 20, 2009 | 02:26 PM
F250_'s Avatar
F250_
IIRC... the tranny cooler for an '05 is the 26-row design, which is slightly smaller than the 31-row design from the earlier models.
Not saying it's bad by any means... just clarifying the difference in case it is important to anyone loooking at the tranny cooler. Either way... either 6.0L tranny cooler is SO much better than the stock 7.3 cooler that you'd be a winner either way.
Old Aug 20, 2009 | 02:28 PM
jeff7825's Avatar
jeff7825
I would also be interested in the power rear glass if it is indeed the power rear sliding window. And also if it came with the wiring harness.
Old Aug 20, 2009 | 02:40 PM
stroken's Avatar
stroken
I got dibs!
Old Aug 20, 2009 | 02:52 PM
brian42's Avatar
brian42
Veteran: Navy
Was the 31-row from the '03-'04 6.0 only? That seems odd that they would reduce the size of the cooler (not that they weren't out to lunch when they engineered ours).
Old Aug 20, 2009 | 03:06 PM
tdpower's Avatar
tdpower
There is another 6.0 tranny cooler is the Houston area if anybody is interested. I been keeping my eye out locally but no luck yet!!!!
http://houston.craigslist.org/pts/1318122032.html
Old Aug 20, 2009 | 03:46 PM
dannyboy7.3
Here is another power rear window in the Seattle area for a little more since it seems like a hot item.
http://seattle.craigslist.org/tac/pts/1333143237.html
Old Aug 20, 2009 | 03:54 PM
F250_'s Avatar
F250_
Here's what I know for sure. The '03's and '04's were 31-row, and the '06's and '07's were redcued to the 26-row design. Not certain if that changed happened at the end of the '04, mid-'05, or end of '05 models.
I also have not been able to secure a heat transfer ratings between the two versions, but either way, even the 26-row units are bigger than the V-10's, so they will provide tremendous cooling capacity.
Old Aug 20, 2009 | 06:28 PM
Izzy351's Avatar
Izzy351
The 26-row is worth it. I put it in mine and it dropped the temps an easy 50 degrees. I have to *REALLY* be hammering it in 100 degree ambient temps to get it to 180, and it cools back down to ~150-160 after. I would jump on either one...
