1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
Picture of rear wiper mechanism?
Old 08-19-2009, 09:47 PM
bigshotsho93's Avatar
bigshotsho93
bigshotsho93 is offline
I need some help. Can someone open their rear window and take a picture of the round disc that contacts the wiper arm, and a picture of the back side of the wiper arm. My rear wiper doesn't move. The motor turns and the wiper sits still. The wiper turns by hand. There is a piece missing between the round plastic disc and the back side(inside) of the wiper arm.
My expy is an 04 Expedition 5.4 Eddie Bauer 4X4 every option but navigation. Just a couple of pictures would be great.
thanks
mike
Old 08-19-2009, 11:39 PM
madsonp's Avatar
madsonp
madsonp is offline
Try popping the cover off where the wiper arm attaches to the shaft and tighten up the nut.
Old 08-20-2009, 09:32 PM
mvoeller2's Avatar
mvoeller2
mvoeller2 is offline
Don't have a picture. There is a spring loaded pin on the liftgate glass side of the wiper arm. This is what engages into the wiper motor disc when you close the liftgate glass. Sounds like it is either stuck in the pushed in position, or it came out. You will probably have to replace the wiper pivot shaft assembly if it came out. I would try and push on the pin with a small screwdriver, maybe it just got hung up.
Old 08-20-2009, 10:33 PM
Totoro's Avatar
Totoro
Totoro is offline
I didn't get around to taking photos when I took apart the rear wiper pivot arm assy. The shaft was binding on mine. But here's a drawing of the glass side of the rear wiper assy. The red arrow points at a little spring loaded shaft that would mate with the hole in the black disc on the motor side.
https://www.ford-trucks.com/user_gal...?albumid=39531
As mvoeller2 indicated, it does occasionally get bound up and stuck in a depressed position.
Old 08-21-2009, 01:37 PM
bigshotsho93
thats it. i am missing the spring loaded shaft part. there is a bare arm with a little nub, but no spring loaded shaft.
think il hit up a few scrap yards to see if i can pirate that piece.
thanks guys
mike
phoneman91
62
03-13-2024 09:16 PM
asavage
Aerostar
10-06-2015 01:46 AM
alloro
13
09-02-2015 12:53 PM
F150III
12-28-2013 09:20 PM
Smurf-Slayer
18
12-24-2005 11:18 AM
Quick Reply: Picture of rear wiper mechanism?
