Wrong radiator??
Old Aug 19, 2009 | 04:51 PM
sgtpen's Avatar
sgtpen
Wrong radiator??
Just ordered a radiator from Ford for my 1996 F-150. It came in but it has two additional outlets on the left side. Oil cooler maybe? I got the tow package when I purchased so I thought I had super cooling. Can someone confirm for me that the holes are for an oil cooler and thats the difference between a radiator with super cooling and one without? Or maybe its the wrong one??
Old Aug 19, 2009 | 05:03 PM
EPNCSU2006's Avatar
EPNCSU2006
You're talking about fittings in the end tank? Those are the automatic transmission cooler. Most replacement radiators will have the cooler so that it can be installed in either a manual or automatic truck. The super cooling radiator has two rows of tubes while the standard radiator only has one row.
Old Aug 19, 2009 | 05:19 PM
sgtpen's Avatar
sgtpen
yes fittings on the end tank. This is good news then. However it did not come with caps for the fittings. I'll call Ford. Thanks
Old Aug 19, 2009 | 05:48 PM
sgtpen's Avatar
sgtpen
Just took another look and the darn thing is all dented up. Here are a few pics..
http://gallery.me.com/sgtpen/100028
Going to take it back...crud
Old Aug 19, 2009 | 05:56 PM
Diesel_Brad's Avatar
Diesel_Brad
You dont need caps for the two extra holes. ATF flows thru them. No coolant goes thru there
Old Aug 19, 2009 | 06:42 PM
Old93junk's Avatar
Old93junk
It must have been sent UPS....United Package Smashers........Yeah, send it back, that damage was caused in freight handling.
Old Aug 19, 2009 | 09:21 PM
sgtpen's Avatar
sgtpen
Yep..It was sent UPS to the dealership.
Old Aug 19, 2009 | 09:22 PM
sgtpen's Avatar
sgtpen
good point. Didn't think of that. Guess I don't need to cap that off.
Old Aug 19, 2009 | 09:27 PM
Volvo92906's Avatar
Volvo92906
Correct. No fitting go in those empty spots. If you had transmission oil cooling lines they would connect to the spots on your radiator and the ATF would run through this side tank and cool the fluid then flow back int your transmission. You do not need to worry about any of this. Just hook up and upper and lower radiator hoses as you would normally do.
Old Aug 19, 2009 | 09:35 PM
danr1's Avatar
danr1
Yea they might I guess depending on the vendor but I bought one for a manual trans a couple months ago for my sons bronco and it was cheaper then one for an auto. Wasn't a lot cheaper no but saved some 20 bucks, brought the price down under a C note.
If you don't need trans cooler built in see if you can get one without for less money. The manual model may have been out of stock so they just sent you that one too?
Oh and no, I wouldn't accept that one. Maybe for half price I might depending on how bad it is.
Old Aug 19, 2009 | 09:38 PM
sgtpen's Avatar
sgtpen
Thanks DANR1....Wanted to install an OEM radiator. Anyone had issues with an aftermarket? I think I can get one allot quicker and a lot cheaper.
