Rearend randomly got higher?!
Old Aug 19, 2009 | 04:17 PM
gthbryce's Avatar
gthbryce
A couple days ago I noticed that my rear wheel wells suddenly had enough space between them and my wheels i could practically fit my body in them. In other words what would cause the rear of my truck to be higher randomly? Bad shocks? This does not make since to me but I swear the rear end of my truck is higher. I will take pictures if necessary...
<a href="http://img35.imageshack.us/i/truck002e.jpg/" target="_blank"><img src="http://img35.imageshack.us/img35/9805/truck002e.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" />
<img src="http://img35.imageshack.us/i/truck002e.jpg" border="0" alt="" />
Old Aug 19, 2009 | 04:34 PM
andym's Avatar
andym
That makes no sense. It can't be the shocks. We're going to need before AND after pics, preferably next to a tape measure.
Old Aug 19, 2009 | 04:38 PM
capn kirk's Avatar
capn kirk
look close at your leaf springs, shackles, and rear end angle something shifted if it moved
Old Aug 19, 2009 | 04:47 PM
48' fordster's Avatar
48' fordster
Someone stole your rear end man and swapped it out!!!!! haha jk, that makes no sense to me...some before and afters please.
danr1's Avatar
danr1
Got air shocks? someone add air to em?
I must agree its kinda a strange thing to think? notice? wonder?, seemingly it got higher?
Have it serviced and all weight was removed, suspension left to sit at full drop for a extended period? Shackles froze up in full forward/straight down position?
Yea before and after shots might show something.
Old Aug 19, 2009 | 04:59 PM
skaterbro's Avatar
skaterbro
Are you sure it's not the front end that dropped down, making it look like the rear is raised?
Old Aug 19, 2009 | 05:26 PM
gthbryce's Avatar
gthbryce
No the front end isn't sagging or lower. But is there any benefit to having my rear end so much higher than the front? I think its on blocks? or are the called wedges? Maybe I was just being crazy.. After looking at a before picture it looks almost exactly the same. lol
[img=http://img149.imageshack.us/img149/8396/truck003.th.jpg]
Old Aug 19, 2009 | 05:32 PM
skaterbro's Avatar
skaterbro
Call them either or, it's the same difference. Take them out and you should be level. Only benefit i've seen from having the rear higher is while hauling a load back there. Loosen all 4 u-bolts, but remove the blocks one side at a time to keep things simple.
Old Aug 19, 2009 | 05:38 PM
danr1's Avatar
danr1
Those blocks are stock. Your front is likely sagging but before we condemn it to the ole sagging front end condition lets see a picture of a full side view of the truck. Then one of the front, get down kinda low and straight on so we can see both front wheels in the shot.
Old Aug 19, 2009 | 05:41 PM
gthbryce's Avatar
gthbryce
<a href="http://img10.imageshack.us/i/truckjfb.jpg/" target="_blank"><img src="http://img10.imageshack.us/img10/2196/truckjfb.th.jpg" border="0" alt="Free Image Hosting at www.ImageShack.us" /></a><br /><br /><a href="http://img604.imageshack.us/content.php?page=blogpost&files=img10/2196/truckjfb.jpg" title="QuickPost"><img src="http://imageshack.us/img/butansn.png" alt="QuickPost" border="0"></a> Quickpost this image to Myspace, Digg, Facebook, and others!
Old Aug 19, 2009 | 05:46 PM
capn kirk's Avatar
capn kirk
same reason you have shocks on any other vehicle--basically a spring is only good for holding the vehicle up and it will bounce all it can what shocks do is control the spring preventing your car from bouncing like a tennis ball down the road
Old Aug 19, 2009 | 05:48 PM
danr1's Avatar
danr1
Shocks do not hold weight, well air shocks do but thats not the point here, shocks control the weight and the dampen against the springs.
With no rear shocks the back of the truck would bounce up and down for miles after hitting a small dip in the road. Bounce uncontrolled and the wheels would leave the road surface on smaller bumps/holes in the road. A gravel road with "washboard" ripples would be impassable for ya in it.
Haul lots of weight? ya need heavy duty shocks to help keep it under control.
Old Aug 19, 2009 | 05:53 PM
gthbryce's Avatar
gthbryce
I should not have had to ask a noob question like that but thanks for the information.
Diesel_Brad's Avatar
Diesel_Brad
The rear of the truck is higher than the front for 2 reasons
1. When you put a lot of weight in the back, the truck will sit level. This is done to keep weight on the steer tires so you can keep control.
2. Air flows over the top of the truck easier than underneith it. With the back higher than the front, more air goes over the truck then under it causing less wind drag in turn better MPG
Old Aug 20, 2009 | 02:22 AM
phoneman91's Avatar
phoneman91
Is your driveshift one piece?? If so--have your checked the splines at the slip yolk??
