AC Question
Old Aug 19, 2009 | 01:00 PM
jls8177's Avatar
jls8177
AC Question
I have a 99 F350 and the AC is acting up. When I start the truck, it works perfectly, nice and cold. When the compressor disengages (cycles off), it will not come back on.
I can get out and physically push on the front of the compressor and it will engage but it will not engage on its own after it cycles off.
Anybody have any ideas or tests that I can run to try and figure out? My uncle thinks I need a new clutch but I don't know anything about AC. Can I change the clutch without evacuating and refilling the system?
Thanks for any info.
Jason
Old Aug 19, 2009 | 01:11 PM
just another truck's Avatar
just another truck
Pull the connector off and do a resistance reading. This will check the coil that brings in the clutch pack.
Old Aug 19, 2009 | 01:32 PM
12ozd's Avatar
12ozd
Check the clearance on the clutch,may have to remove a shim to get it in specs.
Here's an oldie but a goodie from POP
https://www.ford-trucks.com/forums/5...ml#post4464164
Old Aug 19, 2009 | 01:50 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
Easy fix!! Just fillow the link above and remove some shims and you will be chillin in no time.
Old Aug 19, 2009 | 01:51 PM
just another truck
I was really thinking a weak coil.. I guess i am going to have to save this one..
