Cold Start - Fuel Injection?
Old Dec 1, 2002 | 08:55 AM
turfquip's Avatar
turfquip
Post Cold Start - Fuel Injection?
Re: 1996 F-250 w/351
The past few mornings I've had trouble starting the truck. The engine turns over but will not start on it's own. When I press the pedal to the floor it starts no problem, but will not stay running when I let off the pedal altogether. Then after 30 seconds to a couple minutes then truck acts as if normal, and continues to start and run fine for the rest of the day.
Any advice?
Thanks! Ed
Old Dec 1, 2002 | 06:48 PM
joetee10's Avatar
joetee10
You might want to test, replace, or clean your idle air control motor. It is mounted on the side of the throttle body and could cause the symptoms you describe.:-X12
Old Dec 9, 2002 | 11:06 AM
77redf250's Avatar
77redf250
could be the coolant temperature sensor this acts like a choke to richen the air fuel mixture when cold.
Old Dec 9, 2002 | 11:40 AM
77sc's Avatar
77sc
I've had the same problem. It doesn't run very well or idle until warmed up. '90 with 4.9/5 speed. I'll check my sensors. It smells rich as well.
Thanks
Old Dec 11, 2002 | 03:02 PM
gasman6674's Avatar
gasman6674
I had a similar problem with the exception of it did it all the time.
I thought along the same line as the other responses. Long story short it was a bad distributor cap.
Hope this helps
Gasman
Do you have Gas?
Propane Execeptional Energy
Old Dec 19, 2002 | 11:33 PM
rebocardo's Avatar
rebocardo
You should read your codes before, during, anfter it has warmed up. The computer will tell you which sensors are out of range. This is the first step on any starting problem with a CPU controlled vehicle and will save you money and time.
Old Dec 20, 2002 | 12:23 PM
RBrendel's Avatar
RBrendel
the first thing you need to do is perform a full tune up, caps, rotors, plugs, wires etc. be sure to set the timing as well. maybe look into a msd ignition as it cured the cold starts on my 351w. change the fuel filter and check sensors. good luck.
Old Dec 21, 2002 | 12:34 PM
steve83's Avatar
steve83
I'd definitely agree with pulling the codes FIRST (many parts stores do it free), but it sounds like leaking injectors. Holding the pedal floored during starting triggers the computer to clear a flooded condition by NOT opening the injectors until the engine actually starts. The fact that yours runs rough if you let off while it's still cold also sounds like a flood, which on EFI could almost only come from leaky injectors. When the engine warms up, it can vaporize any excess fuel.
Or it could be a bad TPS, or something else... Pull the codes.
Old Dec 25, 2002 | 08:56 PM
Chas1234's Avatar
Chas1234
I worked on a 1992 or 1993 e150 with a 351w the engine had the same start up problems you are having . In order to fix the problem first unplug the negitive battery terminal then remove the the intake hoses from the throtlebody. (Check and see if the throtlebody has a sticker on it) If it does it should say NOT to clean it. Disrgard this at this time then remove the idial compensator from the throtelbody and clean it with throtelbody cleaner then remove the intake airtemp sensor and clean that too . The intake temp sensor is pretty cheap so I would recomend that you buy a new one. Install the new\cleaned parts reconnect the battery see if it runs correctly.
If it does then clean the throtle body opening and the throtle plates . Be sure to open the throtle and wipe out arounf the plates and where they close and seal to the t-body . Hope this works it did for me
Jon, 1989 F150 4X4
1975F100 4X4
Old Dec 25, 2002 | 09:34 PM
horsepuller's Avatar
horsepuller
FTE Leadership Emeritus
FTE Emeritus
Old Dec 26, 2002 | 10:09 AM
EPNCSU2006's Avatar
EPNCSU2006
Another thing you can check is the fuel pressure regulator. Pull the vacuum hose off the back of it and see if there is fuel in it. If there is, then the regulator should be replaced. This is a pretty simple thing to check, so it's worth a try. And yes, check the codes too.
runner
19
Oct 16, 2024 09:01 PM
hunter444
13
Apr 30, 2014 09:32 AM
wheelie31
23
Apr 5, 2011 10:05 PM
six7bird
Feb 10, 2011 12:44 PM
