engine id?
Old Aug 19, 2009 | 10:03 AM
diesel freak01's Avatar
diesel freak01
engine id?
https://www.ford-trucks.com/forums/8...ne-i-have.html
thats the link to my other thread can anyone help me figure out which engine i have?
Old Aug 19, 2009 | 10:34 AM
hollenjoe's Avatar
hollenjoe
Youve been told already, its a 351m/400, this two engines share everything excpet for the pistons and crankshaft, so they are virtually identical. The 351m was introduced in 1975 and the 400 in 1971, so if the truck is still original and you hace a pre 74 truck you have a 400, otherwise check your vin code, I dont remember exactly were the letter should be but its in the firts 4 digits, so an "S" in the first 4 digits means a 400 and a "H" means a 351m..... If its still unclear measure the stroke ( 3.5" = 351m - 4" = 400), you can also check the crank for a cating code (351m = 1k - 400 = 5mab)..
This is all the info you can possible get to identify your engine, good luck
trck650
1997 - 2003 F150
Mar 13, 2014 01:31 PM
VocaTexas
Aug 12, 2013 07:07 PM
customfer1973
Jun 1, 2011 07:56 AM
ash289
Jun 18, 2008 06:13 PM
Taggart
Feb 15, 2004 08:26 PM
