Need help with Gearing codes
Old Aug 18, 2009 | 04:59 PM
IDIDieselJohn's Avatar
IDIDieselJohn
Found this tag on my axle:
The upper numbers are V132C (not to sure thought)
and the lower ones are for sure 10 10 2 OC14
Also since I was under my truck, I wanted to check the gearing on the ZF5, I have trouble seing it cause the front drive shaft is in my way but where it says *Ratio* theres a few numbers that I can't really see but the last 3 digits are 0.77
Is this enough info to tell me what kinda gearing I got? If not I can go look again.
Thanks
Old Aug 18, 2009 | 05:18 PM
axe_handle's Avatar
axe_handle
What is the two character code on your driver side door tag under Axle say?
You can look up Ford axle codes here:
http://www.drivetrain.com/parts_cata...billofmaterial
Old Aug 18, 2009 | 06:39 PM
IDIDieselJohn
Axle is C5, holy crap I have 4.10 gearing and didn't even know it haha. On the motorhome thought Axle is 53 and theres nothing showing 53 on that page....
Thanks a lot for the link, this is very usefull
Old Aug 18, 2009 | 10:52 PM
Dave Sponaugle's Avatar
Dave Sponaugle
In the bottom row the first two numbers are 10, the 4 is under the bolt head.
L10 would have been the limited slip 4.10 axle.
next set is 10 2 which is a 10.25" ring gear.
Old Aug 19, 2009 | 01:35 PM
84 f250 6.9's Avatar
84 f250 6.9
I want to know my gearing also but there is no tag on my dana 70 rear axle.. truck is 4x4 and has a t19 4 speed and its tachin out right around 70
Old Aug 19, 2009 | 10:42 PM
Dave Sponaugle
With stock 235/85 tires, a 4.10 should turn 3300 at 74 MPH.
A 3.55 will turn 3300 at 85 MPH.
Are you sure you have a Dana?
Fill plug on the back cover of the differential?
Sterling fill plug on the drivers side of the pinion on the front of the differential.
They look almost identical, the fill plug location if the fastest give away.
Old Aug 19, 2009 | 10:47 PM
AndysFords's Avatar
AndysFords
I would bet that if it tachs out around 70 it is 4.10. My 84 t19 4.10 gears tachs out at 72. My 84 with 3.55 will run way past the end of the speedo(85).
IDIDieselJohn
1103
Jan 24, 2022 09:57 AM
IDIDieselJohn
16
Aug 17, 2015 03:42 PM
IDIDieselJohn
31
Sep 7, 2013 01:31 AM
IDIDieselJohn
Jan 30, 2012 01:37 AM
IDIDieselJohn
36
Aug 29, 2010 12:44 PM
