need help carb is spitting
Old Aug 18, 2009 | 12:53 AM
sandiballs287's Avatar
sandiballs287
my 2 barrel is spitting on of fuel when i press the gas alittle when i try to start it. i go to crank it up and and then sits there turning i press the gas and it starts spitting like crazy. psps psps. it doesnt do it unless i tap the gas pedal. i also saw alittle flame come out here. can some one help me out please. what could it be?? heeeellllllllllppppppp meee.
Old Aug 18, 2009 | 09:07 AM
Madathlon's Avatar
Madathlon
Without knowing what engine you have, My guess is your timing chain has worn and jumped
Old Aug 20, 2009 | 01:46 AM
sandiballs287
well i was reading up on it and i remember taking out the dist. so i adjust the timing and it started no problem, but i cant seem to keep the truck running. i try to adjust the carb by putting the idler the highest and then adjust it down and then it tries to idler a normal low idle then just turns off. im goin to change the the plug wires and see what itll do.
Old Aug 20, 2009 | 08:04 AM
Madathlon's Avatar
Madathlon
More onfo about what you have may be helpfull
Old Aug 20, 2009 | 03:37 PM
CougarJohn's Avatar
CougarJohn
Pull the distributor cap and have your wife turn the engine over while you watch the rotor. If the rotor doesn't turn, the timing gear or chain is busted.
Old Aug 20, 2009 | 10:29 PM
orich's Avatar
orich
Hmm sounds ilke your timing is, but was it running ok b4 you messed with it?? Did you set the dissy to #1 which is on the passenger side or to your left looking at the motor if it's a fe...Some people make this mistake and time it like the GM Motors by using the right hand plug as #1. But what motor is yours Like post b4 need more info...
